Ir para o conteúdo principal
Macintosh PowerBook 165c Trackball Replacement
O que você precisa
  1. Macintosh PowerBook 165c Trackball Replacement, Battery: passo 1, imagem 1 %32
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c Trackball Replacement: passo 2, imagem 1 %32
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c Trackball Replacement, Input/Output Door: passo 3, imagem 1 %32
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c Trackball Replacement: passo 4, imagem 1 %32
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c Trackball Replacement, Lower Case: passo 5, imagem 1 %32
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c Trackball Replacement: passo 6, imagem 1 %32
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c Trackball Replacement: passo 7, imagem 1 %32
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c Trackball Replacement: passo 8, imagem 1 %32 Macintosh PowerBook 165c Trackball Replacement: passo 8, imagem 2 %32
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c Trackball Replacement: passo 9, imagem 1 %32 Macintosh PowerBook 165c Trackball Replacement: passo 9, imagem 2 %32
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c Trackball Replacement, Trackball: passo 10, imagem 1 %32 Macintosh PowerBook 165c Trackball Replacement, Trackball: passo 10, imagem 2 %32
    • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
    • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
    • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
  11. Macintosh PowerBook 165c Trackball Replacement: passo 11, imagem 1 %32
    • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
  12. Macintosh PowerBook 165c Trackball Replacement: passo 12, imagem 1 %32
    • Remove all four components of the trackball assembly by lifting upward.
    • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
Conclusão
Uma outra pessoa concluiu este guia.
John
Membro desde: 10/12/11
88 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-3, Regan Fall 2011 Membro de Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 1,272
