Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Macintosh PowerBook 1400 Series Keyboard Replacement
O que você precisa
  1. Macintosh PowerBook 1400 Series Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 3, imagem 1 %32
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Keyboard Replacement, CD-ROM Drive: passo 4, imagem 1 %32
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 5, imagem 1 %32
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 6, imagem 1 %32
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 8, imagem 1 %32
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 9, imagem 1 %32
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 10, imagem 1 %32
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 11, imagem 1 %32
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 12, imagem 1 %32
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 13, imagem 1 %32
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 14, imagem 1 %32
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 15, imagem 1 %32
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 16, imagem 1 %32
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 17, imagem 1 %32
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 18, imagem 1 %32
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 19, imagem 1 %32
    • Remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Sean Bent
Membro desde: 04/01/11
41 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-39, Forte Spring 2011 Membro de Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 2,419
