Ir para o conteúdo principal
Macintosh PowerBook 1400 Series CD-ROM Drive Replacement
  1. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 2, imagem 1 %32
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 3, imagem 1 %32
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement, CD-ROM Drive: passo 4, imagem 1 %32
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 5, imagem 1 %32
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 6, imagem 1 %32
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 10-39, Forte Spring 2011 Membro de Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 26
Últimos 30 dias: 77
Ao todo: 3,167
