Ir para o conteúdo principal
Macintosh IIsi Hard Drive Replacement
O que você precisa
  1. Macintosh IIsi Hard Drive Replacement, Top Case: passo 1, imagem 1 %32 Macintosh IIsi Hard Drive Replacement, Top Case: passo 1, imagem 2 %32
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: passo 2, imagem 1 %32 Macintosh IIsi Hard Drive Replacement: passo 2, imagem 2 %32 Macintosh IIsi Hard Drive Replacement: passo 2, imagem 3 %32
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Macintosh IIsi Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Macintosh IIsi Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: passo 4, imagem 1 %32 Macintosh IIsi Hard Drive Replacement: passo 4, imagem 2 %32 Macintosh IIsi Hard Drive Replacement: passo 4, imagem 3 %32
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
Conclusão
4 outras pessoas executaram este guia.
Chris Green
Membro desde: 10/11/09
36.978 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
2 comentários
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - Responder
Is there a way to read the HDD on a PC?
Charles - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 3,950
