Ir para o conteúdo principal
MacBook Unibody Model A1342 Lower Case Replacement
O que você precisa
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: passo 2, imagem 1 %32 MacBook Unibody Model A1342 Lower Case Replacement: passo 2, imagem 2 %32 MacBook Unibody Model A1342 Lower Case Replacement: passo 2, imagem 3 %32
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
Conclusão
74 outras pessoas executaram este guia.
2Comentários do guia
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Responder
Would the Macbook Pro back cover also fit this?
wow - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 98
Ao todo: 70,866
