Ir para o conteúdo principal
MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement
O que você precisa
  1. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: passo 2, imagem 1 %32 MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: passo 2, imagem 2 %32 MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: passo 2, imagem 3 %32
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, Battery: passo 3, imagem 1 %32
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: passo 4, imagem 1 %32 MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: passo 4, imagem 2 %32
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
  5. MacBook Unibody Model A1342 AirPort/Bluetooth Cable Replacement: passo 5, imagem 1 %32
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the right speaker.
Conclusão
10 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 25
Duração total: 14,561
