Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
The access door should now be raised enough to lift it up and out of the Unibody.
Grab the white plastic tab and pull the battery up and out of the Unibody.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Using both hands, lift and remove the lower case off the upper case.
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
After the RAM chip has popped up, pull it straight out of its socket.
293 outras pessoas executaram este guia.
21 comentários
Open back of unit, press two grey sides surrounding the chip, pull out the top (leave the bottom 2gb in) put in the new (4gb) chip; now there are 6gb of ram.
I just upgraded to 2 4GB chips. Works fine sofar!
That's awesome! I thought that I could only upgrade the RAM to 4GB (which is what I have now). Can you give me the type of RAM that you installed? I have this exact model MacBook.
Jonathan -
Uh oh. I replaced my 2 1GB ram with 2 2GB. I turned it on and it beeps at me about every second, the front status light blinks in time, but nothing else....what next?
Sounds like bad RAM. I would contact who you purchased it from. If it was us, email support [at] ifixit [dot] com
