Introdução
Replace the aluminum bottom case in a MacBook Unibody.
O que você precisa
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
15 outras pessoas executaram este guia.
1Comentário do guia
Is there a way to get replacements for the rubber feet without replacing the entire lower case and access panel?
