Ir para o conteúdo principal
MacBook Pro 17" Unibody Hard Drive Bracket Replacement
O que você precisa
  1. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Lower Case: passo 1, imagem 1 %32
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 2, imagem 1 %32 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 2, imagem 2 %32
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: passo 3, imagem 1 %32 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: passo 3, imagem 2 %32 MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Battery: passo 3, imagem 3 %32
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive: passo 4, imagem 1 %32
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 5, imagem 1 %32
    • Remove the hard drive bracket from the upper case.
  6. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 6, imagem 1 %32
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
  7. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 7, imagem 1 %32 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 7, imagem 2 %32
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
  8. MacBook Pro 17" Unibody Hard Drive Bracket Replacement, Hard Drive Bracket: passo 8, imagem 1 %32
    • Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
  9. MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 9, imagem 1 %32 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 9, imagem 2 %32 MacBook Pro 17" Unibody Hard Drive Bracket Replacement: passo 9, imagem 3 %32
    • Tilt the outer hard drive bracket up toward the logic board and remove it from the rear case.
Conclusão
10 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
463.213 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 16.243 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 4,547
