Ir para o conteúdo principal
MacBook Pro 17" Unibody fixing noise fan and overheat
O que você precisa
  1. MacBook Pro 17" Unibody  fixing noise fan and overheat, Before starting: passo 1, imagem 1 %32
    • I am using Husky screwdrivers HD 74501 U & HD 74502 Y
  2. MacBook Pro 17" Unibody  fixing noise fan and overheat, Getting ready: passo 2, imagem 1 %32
    • Turn your MBP upside down
  3. MacBook Pro 17" Unibody  fixing noise fan and overheat, Screws first: passo 3, imagem 1 %32
    • Remove the screws from the back cover
  4. MacBook Pro 17" Unibody  fixing noise fan and overheat, Open it !: passo 4, imagem 1 %32
    • Carefully open the back cover.
  5. MacBook Pro 17" Unibody  fixing noise fan and overheat, Dust ? No, thanks !: passo 5, imagem 1 %32
    • Remove the dust . I am using a vacuum cleaner here with a brush.
  6. MacBook Pro 17" Unibody  fixing noise fan and overheat, Apple warranty: passo 6, imagem 1 %32
    • Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
    • Keep your Apple warranty and disconnect the battery.
  7. MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: passo 7, imagem 1 %32 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: passo 7, imagem 2 %32 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: passo 7, imagem 3 %32
    • Disconnect the fan from the mainboard.
  8. MacBook Pro 17" Unibody  fixing noise fan and overheat, Almost there !: passo 8, imagem 1 %32
    • Remove the 3 screws that fron the fan fixture.
  9. MacBook Pro 17" Unibody  fixing noise fan and overheat, Take a walk on the wild side !: passo 9, imagem 1 %32
    • Clean the dust with a very soft toilet paper.
  10. MacBook Pro 17" Unibody  fixing noise fan and overheat, Finally!: passo 10, imagem 1 %32
    • This is what I´ve found inside one fan !
Conclusão
12 outras pessoas executaram este guia.
LAOMUSIC ARTS
Membro desde: 02/25/17
589 Reputação
Autoria de 1 guia
6 comentários
I’d be careful about using a vacuum cleaner on the inside of the computer as it can cause static discharge and zap your components.
pov - Responder
Sanzi Gao - you are welcome!
LAOMUSIC ARTS - Responder
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Kendall Lui - Responder
Since my 2008 Macbook Pro has been overheating for a while I tried this. Unfortunately everything inside is quite clean: no dust in the fans or heat-sinks.
The fans run quite well , and get going pretty fast as the device heats up. Any other ideas are welcome, This was a GREAT machine and I miss using it.
Eric Hammond - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 47
Duração total: 9,328
