Introdução
Removing a few screws will remove this part and allow access to your RAM.
Ferramentas
Peças
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
7 outras pessoas concluíram este guia.
