Introdução
Does your display flicker when you rotate it about the hinges? A worn-through display data cable may be the cause.
O que você precisa
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
To Damon - possibly the thread on the bottom of the upper case is obstructed.
I found that I needed to fight the latch magnet with the right-most screw in the photo. The screw was pulled away from the hole so a magnetized screwdriver was not enough to place it. I needed tweezers to hold the screw in place until it bit.
No, these screws won’t bite going back in — struggled for an hour. Lost hope of success.
Case screw holes perfectly lined-up, neatly closed body, screw threads/head are fine (Apple quality screws), perfect screwdriver.
The left one is in, other two simply will not bite whatsoever. Slightly irritating eventually turned to madly infuriating. I have a similar, earlier model and that was smooth to replace these exact, slightly angled screws (so I have experience).
Q: Are the centre and right-hand screws absolutely essential — or can I give up and leave them out?
(By the time you read this, that’s what I’ll have done)(out of sheer frustration)
Remove the following six screws:
Two 14.5 mm T6 Torx screws on either side of the RAM slot.
Four 3.4 mm Phillips screws along the hinge.
These instructions are actually wrong. The 14.5 mm screws are for along the hinge, the 2 on either side of the RAM slot are about 10 mm.
Remove the four 3.4 mm Phillips screws on the port side of the computer.
When reassembling, please be careful not to screw into the wrong spot. I accidentally screwed into the DVI port and it was hard to remove the screw after that. I had to disassemble the whole thing again, only to find that I couldn't remove the screw from within as it was encased. After much scraping and prodding with a sewing needle, I was able to get that screw out. Phew!
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Be very careful not to bend the screw tabs on the top case the perimeter screws attach to. Bending them causes them to quickly fatigue and potentially break off. When reassembling the top case, be sure the tabs are all *inside* the case before reseating it. If you get resistance, pull the case back up, check the tabs and reseat the top case again.
Disconnect the trackpad and keyboard ribbon cable from the logic board.
Remove the upper case.
Disconnecting this cable is optional, if instead you tip up the top case ~75 degrees, propping it up with something non-metalic (wedged in or by the battery compartment). Unplugging a connector from the main circuit board always carries slight additional risk.
It's not really necessary to disconnect the trackboard/keyboard ribbon cable. You can simply lean the upper case against the LCD.
After having successfully removed/reattached the ribbon cable several times while trying to revive this computer for back-up use the securing/release tabs on the connector broke. The connector then will not hold the cable properly and connecting fails. Tried various methods of propping the cable in the connector to get full contact but eventually all efforts failed, too. Result: essentially a dead motherboard as no replacement for the connector seems available. Sadly, not worth the extra effort to try further repairs.
Disconnect the two antenna cables from the AirPort Extreme card, the iSight and inverter cables from the left side of the logic board, and the display data cable from the right side of the logic board. Be careful to slide the connectors as they may become damaged otherwise.
Carefully peel the iSight and inverter cables off the top of the left fan and de-route the AirPort antenna cables from the channel in the left speaker.
anybody got any advice re: how to detach the connector on that tiny little ribbon, the one on the upper left with the larger ribbon/connector alongside it? I tried and tried... gave up for fear of damaging the wires, plus concern about how difficult it might be to get it back in. Thx in adv
Firenzeitalia: The tiny little black one is the scariest part of the whole job. You need to use a firm spudger to slide it out to the left. Possibly even use the pointy end, but it slides out quite easily.
The hard part is getting it to slide back in again later — especially if you have large fingers. Essentially, you’re going to have to do it blind — and by ‘feel’ — because you can’t see what you’re doing.
Fortunately, Apple made it so that the black housing lines-up to the sides and the four tiny receptor prongs: once you’ve slid it into place and it looks correctly in, you then push down on it — to snap it in properly.
This is the time to re-attach the keyboard (put a cloth over the screen), plug in power and turn the machine on to test you’ve done it right.
If you’ve attached the tiny Inverter housing correctly, the screen will light up and boot as expected. If the screen remains black, remove the keyboard and cable again — gently — and check the Inverter and Display Data Cable are correctly inserted.
Remove the ten silver T6 Torx screws securing the display (five on each side-take note that the inside screws on both sides are longer with a thinner head).
To clarify the placement of the different screws:
There are two sets of 2 on each side and two sets of 3 on the insides. The "long" screws with "flat" heads are meant for the INSIDE of the sets of 3. I will represent short screws by the letter "S" and the long screws by the letter "L":
S S - S S L - L S S - S S
But what are the measurements of the screws? Its T6 but how many millimeters long is the screw?
The longer two (middle) screws are about 14mm and the rest (identical) are approximately 10mm.
Grasp the display assembly on both sides and lift it up and out of the computer.
If you came to the Display Removal guide to replace just the LCD panel and not the entire assembly, you need to head over to the Front Bezel replacement guide.
Remove the Phillips screws from the lower left and right corners of the display (two screws total).
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Insert the flat end of a spudger into the gap between the rear display bezel and the clutch cover.
Twist the spudger to separate the lower edge of the rear display bezel from the clutch cover.
Work along the lower edge of the rear bezel until it is evenly separated from the clutch cover.
Now that the right and bottom edges of the rear bezel are slightly separated from the front bezel, use a spudger to pop the rear bezel off the tabs near the lower right corner of the display.
Prying the rear display bezel off up with the plastic spudger can be frustrating. The plastic spudger just can't provide the torque. I actually used the combination of the plastic spudger (to start the separation) and a metal spudger to provide sufficient force to separate. I wrapped the metal spudger with some tape to prevent scratching. As usual, care is required to not bend the front bezel.
Remove the piece of tape securing the backlight cables to the front display bezel.
Disconnect the inverter cable by pulling its connector away from the socket on the inverter board.
During my LCD replacement, I did not do this, nor remove the inverter board, I just unplugged the cord in step 24 and left the inverter board in the clutch cover assembly.
Use the flat end of a spudger to carefully peel off the three antenna straps stuck to the lower edge of the LCD.
Be careful pulling off the kapton tape. Because of the age of the computer and the continuous heating and cooling, the tape can become brittle and the adhesive will stick to the surface of the LCD and not the tape itself, making it unusable. If this happens, you can find small rolls of kapton tape on the internet or get it in the ifixit store.
Remove the five Phillips screws securing the clutch cover to the bottom edge of the front display bezel.
If you are replacing the LCD and not the front bezel, you really don't need to remove the clutch cover and clutch hinges. You have full access to the LCD screws and can remove it, skipping this step, as well as the steps 29, 30, 31, 32, 37 and 39. The clutch cover, inverter board and all cables will remain attached to the front bezel.
The cables didn't fit right when I put the clutch onto the front bezel so I tried to disassemble but the middle screw is stuck. The tiny little cable that's connected to this screw ripped :( If I do manage to get the screw out, not sure if I have to replace this whole cable even though it's just a small side cable connected to the inverter cable I think.
Finally got the screw out, and put the cables in the clutch assembly correctly. Works despite the isight/inverter cable's tiny second thread having been torn.
Take photos of what this looks like bc you have to make sure the cables fit in the clutch and are long enough to fit in the motherboard properly.
While pulling the clutch assembly away from the clutch hinge with one hand, insert an iPod opening tool between the clutch cover and the front display bezel to lift the clutch cover over the retaining pin on the front display bezel.
Pull the clutch assembly away from the front display bezel.
Before you completely detach the clutch assembly, take note of how everything is organized inside it, as you will be replicating it upon reassembly. The display data cable ended up being in the way as I was closing everything up and had to reopen everything to readjust it. Take pictures and see how it will fit into place before you reattach the clutch assembly and screw in the 5 screws.
Remove the clutch assembly from the front display bezel, minding any cables that may get caught.
14 outras pessoas executaram este guia.
2 comentários
I need a confirmation the A1261 Screen shown here is the 1920x1200 version (apparently so).
I've found a dismantled complete screen but the only thing shown is the 593-0739 rev.A foxconn 81x cable: I cannot trace which kind of cables' codes are used for the different screen types and I presume they should match the different resolution types for the MBP A1261 17".
Can anyone please help? TIA
Before upgrading to a larger HD, you'll want to "clone" your original HD using the donation-ware program "Carbon Copy Cloner" (http://www.bombich.com/). Put the new HD in an external case; clone the original; test the clone (by starting up with it), then take apart the MacBook to put the new HD in the MacBook, and the original in the external case for use as a backup, etc. (You can't just drag the contents of the original HD to the new HD, and expect it to work; not since the days of OS 9 and before.)
amiller770 - Responder
Can I put more than two gigabytes of RAM in?
Noah Nsangou - Responder
mine has 2g*2=4 gb ram in. you should be fine
on mac forum it suggested to put 4gb and a 2gb in a1261.
david -
I made the mistake of wanting to do a clean install of OS and start fresh after installing a SSD. Now I can't install most browsers on OSX Leopard. Does anyone know what is the most current version of OS I can put on this system? (disk or download) Can I get to Snow or Lion?
2006 17" MackBook Pro Model#A1151
2.16 GHz Intel Core Duo
Memory: Two 1GB 667 MHz
Hard Drive: Corsair Force GS: SSD 128GB
scannon - Responder
You can install OS X 10.7 LION and no later version. Although LION runs ok with 2GB RAM it does help to get 1GB + 2GB = 3GB. Even if you install 2 X 4GB you will only utilize 3GB. Installing a SSD seems to make no difference since the SATA bus is only 1.5GB/s. A good 5400rpm disk is good enough. I even run BootCamp and Windows 7. Works fine. Not fast but fine. My A1212 refuses to die :-)
asle -
There seems to be some discrepancy about whether or not installing a SSD will help. See Phil's earlier comment from October 2015: there, *he* claims that having an SSD increases the load times significantly, (even though -- of course -- 1.5Gbps is not ideal)...
His quotation, (re-)cited integrally:
Just replaced my old HD with a Corsair Force LX SSD (which is SATA 1-3 compatible as required by this model) with success now my old 'outdated' laptop has super fast loading times and is postively flying faster than the speed of 'sound'. Thanks for the guide. Only problem I faced was replacing the top panel which after a few minutes of panic realised the rubber mounted Mic next to the left speaker had risen up when I had removed the top panel so after carefully pushing it back into place the panel fitted back how it should, so beware of this possible problem.
Phil - 10/07/2015
at0gjm -
Bonjour j'ai besoin de cette bactérie que dois-je faire ?
basile kouamé YAO - Responder
