Introdução
Upgrade je RAM voor een snellere laptop.
Verwijder de volgende tien schroeven die de onderste behuizing aan de bovenste behuizing bevestigen:
Zeven 3 mm lange Phillips schroeven.
Drie 13.5 mm lange Phillips schroeven.
Maak de twee lipjes, een aan beide zijden van de chip, los door deze tegelijkertijd naar buiten, weg van de RAM, te duwen.
Nadat de RAM eruit is gekomen, kun je deze direct uit het contact trekken.
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
158 outras pessoas concluíram este guia.
Um agradecimento especial a esses tradutores:
100%
Thomas Keulemans está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
5 comentários
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Never mind. I was able to pop the second chip back out and get it seated properly.
