Ir para o conteúdo principal
MacBook Pro 15" Unibody Mid 2012 Disable 2nd GPU to prevent white screen or green stripes during boot process
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. MacBook Pro 15" Unibody Mid 2012 Disable 2nd GPU to prevent white screen or green stripes during boot process, MacBook Pro 15" Unibody Mid 2012 Disable 2nd GPU to prevent white screen or green stripes during boot process: passo 1, imagem 1 %32
    • 1) Boot Macbook with keys pressed Command + S
    • 2) Wait for active command line
    • 3) Enter these 3 commands:
    • nvram fa4ce28d-b62f-4c99-9cc3-6815686e30f9:gpu-power-prefs=%01%00%00%00
    • nvram boot-args="-v"
    • reboot
    • System should boot without issues.
    • Source: https://forums.macrumors.com/threads/for...
Linha de Chegada
4 outras pessoas executaram este guia.
Cherry
Membro desde: 01/01/16
966 Reputação
Autoria de 5 guias
7 comentários
After nearly 2 weeks internet research, at last a working solution. Heureka! Thanx a lot!
Best regards,
Chris
Christian Gelbke - Responder
keep getting:
Process[207] crashed: opendirecteroyd. Too many corpses being created.
Process[208] crashed: opendirecteroyd. Too many corpses being created.
Process[209] crashed: opendirecteroyd. Too many corpses being created.
etc.
mrtjaet - Responder
This post worked !!!! Thank you so much. I joined IFIXit because of this post.
Ganesh Gupta - Responder
Hello, I have a similar problem with my MacBook pro Early 2011. Do you think, that I can use the same 3 commands?
Sandro - Responder
Key phrase: Boot. I can’t boot my machine. I’m stuck on the white screen of death. It sometimes is pink and other times the external monitor is green. I did all the resets on the Apple side (to PRAM, SMC, etc.), I tried to restore the OS (didn’t work) and I tried to use a different computer to create a working boot drive (USB) and can’t seem to get the command correct for Sierra or High Sierra. The USB Boot I created with Mojave on it could be seen in the Repair boot process but the machine simply shut down mid processing. So I can’t do the entry of the code because I can’t boot or find a terminal or be in verbose mode to do so. My 2011 15” Macbook Pro is running Sierra (was) and I have data on it I very much need - in addition to wanting to see my screens again.
Christne Taylor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 4,361
