Introdução
This guide is an internal guide used as a prereq.
O que você precisa
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
Remove the following three Phillips screws securing the optical drive to the upper case:
One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
