Ir para o conteúdo principal
MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up off the logic board.
  2. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: passo 2, imagem 1 %32
    • Disconnect the camera cable by pulling its connector away from the socket (toward the optical drive) on the logic board.
  3. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: passo 3, imagem 1 %32
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
  4. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: passo 4, imagem 1 %32 MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: passo 4, imagem 2 %32
    • Remove the two Phillips screws securing the AirPort/Bluetooth board housing.
    • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
  5. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: passo 5, imagem 1 %32
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 4.5 mm Phillips screw securing the optical drive bracket to the upper case near the fan.
    • Two 2.5 mm Phillips screws securing the optical drive to the upper case near the optical drive opening.
  6. MacBook Pro 15" Unibody Mid 2010 Optical Drive Replacement: passo 6, imagem 1 %32
    • Lift the optical drive near its connector and pull it away from the upper case to remove it from the computer.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 978
