Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide is a prereq only.
O que você precisa
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
If necessary, use the flat end of a spudger to separate the microphone from the upper case.
Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
Uma outra pessoa concluiu este guia.
