Introdução
Use this guide to replace a worn-out battery. If your battery is swollen, take appropriate precautions.
O que você precisa
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
16 GB is the max
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
nails work pretty well as well...
At first sight I was confused when I read the description at this step, 'cause it seemed that disconnecting the battery connector was optional, in order to eliminate static discharge. While it's a helpful advice in other circumstances (as mentioned as an example changing hard drives), when changing the battery it is not an option - you have to disconnect the battery connector.
It would have been better to mention the optional disconnecting recommendation in a side-note.
Other than that, an excellent guide!
the fact that this step is optional can not be stressed enough. i tried disconnecting the battery and in the process it short circuited which now leaves me with an even more expensive problem than i had before when i just wanted to change hard drives (at least the new hard drive works fine..)
the hard drive changing worked though.
Any tool used to pry on the battery connector must be non metallic, to prevent unintentional short circuit between the connector pins. In my case, my index finger nails were strong enough.
Excellent guide, it was as easy as a breeze to replace my battery. I can't believe I nearly followed Apple in their saying that this part was not user replaceable. Great job for this description, and many thanks. iFixIt is THE reference for Mac owners.
Patrick.
So - I have a weird comment about this. I wanted to make sure that I was getting the right model - so I opened up my laptop and then thought "well, why not just remove the battery while i'm in here, it's shot anyway". Though, I forgot about the stupid screws (Apple really did us over on that one!). Though I disconnected the battery connector and didn't bother to re-connect it when I was finished and just put the cover back on.
Here's the weird part - when I went to turn my laptop back on...MY BATTERY WAS RECOGNIZED...AND WORKING! I was under the impression that the connector "connects" the battery's charge to the laptop, but this just doesn't make sense! Plus, now my very dead battery is in "normal" condition according to the system report. I haven't worked for apple, but have about 5 years of IT experience and am baffled by this! I'm starting to think i've experience a miracle! Has this happened to anyone else?
Possibly disconnecting the battery caused the System Management Controller to reset. That might have been your problem rather than the battery itself. See http://osxdaily.com/2010/03/24/when-and-...
I tried spudging the corner closer to the wires which was probably a bad idea. The corner broke off! I can't believe it was that brittle. So be careful. If it did it again, I'd aim for the corners AWAY from the wires or the sides themselves, though I seem to recall there not being much of a lip.
I used the spudger to gently ease the battery connector out. I then placed a q-tip between the connector and it’s socket to avoid making an accidental connection. A toothpick or some other soft stick might also work.
My battery connector had a shiny metal cover over it like a male USB plug. I had to take the 3 peace symbol screws oit and remove the battery before I could access thr plug properly. My battery plug also came off parallel to the board by walking the black plastic part off the metal part towards the battery. It required quite a bit of force to walk it off the connector. I broke a spudger trying. Something nonconductive but strong like a wittled down bamboo chopstick could work well.
Translate to Spanish:
Para ciertas reparaciones (por ejemplo, el disco duro), no es necesario desconectar el conector de la batería, pero evita cualquier cortocircuito accidental de la electrónica en la placa base. Si no desconecta el conector de la batería, tenga cuidado ya que partes de la placa base pueden estar electrificadas.
Use el borde de un spudger para levantar el conector de la batería hacia arriba desde su zócalo en la placa lógica.
Es útil hacer palanca hacia arriba en ambos lados cortos del conector para "sacarlo" de su zócalo.
The BATTERY MUST BE DISCONNECTED - it is NOT OPTIONAL if you are going to remove the logic board.
These instructions are for Removing The Logic Board, so if that is what you are going to do the battery MUST be disconnected.
The informational item beginning with the words “For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary … “ is NOT applicable to a set of instructions on removing a logic board and it should be deleted from this otherwise excellent set of instructions.
In my opinion the RAM should be removed first - i.e., before the battery is removed.
The RAM DIMMS are just in the way if they are left in their sockets on the logic board until step 33.
I cannot see any useful reason to not remove them very early in the sequence.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
My battery connect was like mid 2010 model
Why not go ahead and remove the battery at this point instead of bending the battery connector back (see steps 23 -25 below)?
Translate to Sanish: Doble el cable de la batería ligeramente lejos de su zócalo en la placa lógica para que no se conecte accidentalmente mientras trabaja.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Where can I suggest that iFixit add a cross-referenced note/warning when purchasing a replacement battery (or other parts that require odd tools) that you also need to purchase yet another special-purpose *&$%#(%@ screwdriver, "because Apple"!!
I had to wait for weeks to find time to complete this repair, and now have to wait weeks longer for another chance.
Note to self: read the entire guide before purchasing, AND before starting the repair, AND while you're doing the repair...
I preferred to use the Y0 for these screws, the Y1 felt too big for the screws they used with my battery.
Are these Tri-wing or Tri-tip? Perhaps there isn't a difference but I've seen references to both.
I found that I could not remove the Tri-Wing screws with the guide recommended Y1 bit. It was way too large and instantly started stripping the screw. The Y0 bit fits perfectly. I believe the guide incorrectly recommends the Y1. There is also a 3rd Tri-Wing screw in the top left corner of the batters (same orientation as the guide) located UNDER a small black plastic flap.
For Logic board removal, I did not find it necessary to remove the 3 tri-point screws or the battery, the board came out no problem.
I did not need to remove the tri-wing screws or the battery to remove the Logic board on my MBP. The logic board comes right out no problem.
As many people above mentioned, I failed to check the tools required. I thought since I’d done other minor fixes/replacements that I’d already have everything I needed but didn’t have that blasted tri-tip screw driver. I got impatient though and forced a small flat head to work with the pliable screw material. Hopefully I didn’t ruin my ability to ever take them out again.
I bought a tool-kit 1.5 years ago to replace the stock HDD with SSD. There’s only one screwdriver of Y type: an index on its facet that reads “CR-V Y2.0“. Will it do? I don’t understand the nomenclature.
Replying to myself: I discovered that that screwdriver is a perfect fit for the screw’s in question bit.
Elijah -
Carefully peel the battery warning label rounded end (the one without glue) off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
Remove the last 7.4 mm Y0 Tri-point screw securing the battery to the upper case.
Two of the three plastic screw eyelets on my old battery were broken - I guess someone had dropped the computer at some time. So these two little bits of black plastic fell down into the Unibody when I lifted the battery out. I’m glad I saw them so they didn’t rattle around and cause trouble later on!
Putting these screws back in was the only problem I ran into – I had to realign the battery a few times before they went in easily.
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
ifixit kit i bought linked to from here says to discharge below 10% then charge to 100%, but this says to charge, then discharge, then charge. Guess I’ll follow the instructions here, but would be good to update the notes to say whether to disregard the card that comes with the kit or not.
The instructions here in the guide are the most up-to-date. It takes a little longer to make changes/updates to printed materials. Sorry for any confusion!
WARNING!
When I lifted my dead battery out, I saw two old 3 mm Phillips case screws lying loose in the bottom of the Unibody. I lifted them out using the magnetism of the Phillips #00 screwdriver.
On gently shaking the case I could hear that there was another loose item still in there somewhere, so I carefully turned the laptop over to have it fall out – and the whole hard disk fell out, though it remained hanging by its cable! I discovered that the two screws holding the retaining strip (that runs the whole length of the hard disk between it and the DVD unit) had been completely loose!
Nothing broke, but it was a nasty surprise!
I had bought this machine second-hand as factory refurbished with twelve months guarantee – and gotten three old case screws and a nasty surprise for free! Apart from that, I’ve been really pleased with it.
I purchased this battery and kit for my late 2011 MacBook Pro on Wednesday and received it today; Monday. Great timing with shipping! Instructions were VERY handy. I almost missed the screw in STEP 6. Thanks for that guys! The kit is exactly what was needed and the battery came out smoothly and replacement went in without any issue!
After there complete discharge, it certainly needed helped figuring out how long to recharge – it kept telling me another hour and 30 minutes or so for a while. I hope now it knows as it is useful to have an idea how long it’s going to take.
How long should it take to drain when using it normally (just websurfing), after charging to 100% and waiting 2+ hours that first time?
I noticed after first full charge, the battery lasted a little less than 3 hours w constant web surfing… will it improve?
yetixhunting - Sep 15, 2022.... Batteries are mass produced. it's not necessary that all the product exhibit the same characteristics.
It's advisable, that you request for a replacement.
The correct procedure to calibrate the new battery after it's installed, is to use it till discharge to 25% and then charge it to 100% and hold the charging process for 2 more hours
Then repeat the process mentioned above namely; (discharge to 25% and charge to 100% hold for 2 hours etc)
This is process is enough to almost stabilize the battery.
But remember, you'd not obtain a result of OEM standards, in any case. Apple standards are very stringent and such standards will be be there in other manufacturers. Meaning 7 hrs continuous use, when new.
FYI the device I'm presently on, is MacBook Pro (15-inch, Late 2011) and I have not replaced the Battery as yet.
I will not discharge more than 20%.
Modifications: 126GB HHD replaced to 256GB SSD. 8GB RAM to 16GB. The system is faster than before.
This machine is the best. Cheers.
Hi, I've just bought a new battery from Ifixit for my mid 2012 MacBook Pro. It works well. But my computer doesn't wake up anymore without the Magsafe charger. Then, I can use my laptop. How do I change this ? Thank you.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
393 outras pessoas executaram este guia.
41 comentários
I'd say this difficulty should be rated as easy, not moderate - it's well written and easy to follow, and documents one of the more simple procedures.
I think they rate it as "moderate" for needing to acquire the "Y" type screwdriver, but, (and here's a protip for first timers...) A small straight-blade actually fits and turns the screw as normal, with no need for special tools. :)
pyrodice -
The guide says to use a Y1 Triwing for the battery screws. The Triwing heads are smaller than that. I had a Y1 and it didn't fit. I kludged it with pliers and a Philips P000.
The Y-1 worked perfectly for me.
Use a small straight-blade. Sounds odd, but works perfectly.
pyrodice -
Very useful. I was having problems with my trackpad, the cursor was jumping around irratically, and I figured the problem was likely to be either swelling of the battery that I could not see, or dust and dirt on the trackpad. I was at the end of my patience, and my warranty has expired anyway, so this time I VIOLATED APPLES' IMPERITIVE and took out the stupid battery. Piece of cake.
Two things I found, 1) the plastic tabs that hold down the battery were all three broken; the screws had been over tightened from the factory. There were small pieces of plastic from it under the battery on the trackpad. When I got the battery out, I found a very tiny screw loose on the trackpad. I have no idea where it came from, I suspect someone dropped it when this unit was put together, since this has been an on- again off- again problem since
I just did this and found a random small black screw… stuck to the back plate! o_0 I also couldn’t figure out where it came from…
the computer was new. I removed the screw and dust, and put three small pieces of Velcro (just the fuzzy side) on the battery so that the back case would hold it in place, since the three ridiculous tri-screws were not doing anything, anyway. And put it back together.
And now, it works very, very well!
Somehow, I think an Apple genius would have not told me about having a screw loose...
Difficulty level should be revised to Easy but perhaps Moderate makes sense depending on how swollen the battery is.
Wasn't even aware that my battery was about to die until my trackpad started to stick and eventually became useless.
In my case, my Early 2011 (MacBook Pro 8,2) battery had over 1,300 cycles and the swollen battery was pressing against the trackpad rendering it basically useless.
Purchased a 3rd party battery off OWC for $99, arrived 3 days later and magic. My cycle count is zero now and the trackback works perfectly.
Easy as can be. I have never done any computer repair work, and this was simple!!! Thank you!
I originally bought a battery from amazon. But the battery did not work at all.
I then bought the battery here and those tools. It was perfectly working and the tools were very precise and easy to use. The quality of tools was much better than my amazon purchases.
I recommend to replace the battery using the iFixit products.
Thanks.
Bought the battery, the tools noted and the process was smooth. Took some care to take the warp out of the base cover and the machine is back in action.
I recommend this and add the note that with the right tools the process was EASY.
Cheers.
Before you remove the old battery and install the new one, make sure that you go in the System Preferences / Date and Time and have them set to "manual" (i.e. check off "Set date and time automatically" to an Apple server). That could save you lots of hassle when rebooting after replacing the battery.
See the thread “krb5kdc + Wrong OS Time + Losing Wifi Password ... | Official Apple Support Communities”, at https://discussions.apple.com/thread/239...
Lami -
Only two little details: I had to plug the new battery in first; then put in the three screws that hold it down. Also would be useful to sort the 4 screw types and match them with the proper holes. Otherwise perfect directions. And I chose to ignore the AUCHTUNG!
So, I replaced the battery, but the machine cuts out after a indeterminate amount of time, necessitating switching it back on again.
This is with no warning, it has done it a couple of times with the battery monitor showing 80% or more.
The machine is completely fine when running on mains power.
Any ideas?
Peter, I just replaced the battery on my MacBook Pro 2011 and I’m experiencing the same as you did. It shuts down unless I have it plugged to the main power. Am I suppose to let it charge for a few hours?
After I replace the battery should I first charge it fully or should I use it first and charge after depleated?
Thank you so much!! Have new life in my early 2011 MPB now!
If the battery is too swollen, this becomes a challenge to perform as some screws don't want to get out. As much as I really, /really/ did not want to and felt a part of me die inside as I did, I actually wound up ripping the bottom case off of the last three screws that just wouldn't get out (the battery's force actually caused one of the three screwholes to pop out of place, I simply bent the bottom case until the other two popped out.) From there on it was smooth sailing.
...Now to wait for my new battery to come in! (I could've had the swollen battery in there until the new battery came in, but honestly, I feel it's better to do without the Mac for a few days for the peace of mind in knowing I'm not going to have to worry about it blowing up or something of the sort at any given moment ^^") I'm going to feel so cool if this all works; I picked up this Mac for just $100 because of the battery swelling issue.
Just want to say thank you! You are selling a formidable battery here. I bought one over at eBay for 50 dollars or so and it works, but only gives me app. 2 hours on a full charge. The battery I got from fixit is a little more but still not as expensive as a proper Apple battery where I live and I get around 6 hours on a full charge. I did a calibration, even though I read somewhere else it shouldn't matter when the battery is internal and "non-removable". Thanks again.
cheers,
-jsteweii
I replaced the battery via your great directions. At first, it seemed to be working perfectly, but then shut off. I turned it on and it worked briefly, but then shut off again. Now it won’t even boot up…What’s going on? Cathy S
Looking to do this repair soon, as my battery is indicating “replace soon” to me.
Did you get your Macbook to work in the end?
Hello everyone. I just installed a new battery on my Macbook. But I can’t seem to calibrate the battery. It won’t give me accurate predictions regarding the percentage and duration of the battery. I have already tried every calibration procedure that I could find. But it just won’t work. Any idea would could be wrong ?
I am just about to replace my swollen battery (ordered with tools from iFixit) however my trackpad is cracked owing to battery swelling - should i buy and replace trackpad at same time to save opening up twice?! Thanks
Harriet - fortunately I read all the comments and questions - including yours. Otherwise I would have described exactly the same problem:
My early 2011 MacBook Pro’s battery is so swollen, that the touchpad sticks out of the keyboard and even the underside of the laptop became curved instead of flat. I wonder whether you got any reply from iFixit? I am afraid to buy the new battery and tools today - only to find out, that more parts need to be replaced which were destroyed by the swollen accu?
Hello Harriet,
After my message yesterday I ordered the replacement battery, and all the three recommended tools. The Phillips and the Tri-Point screwdrivers as well as the spudger. I almost didn’t believe it: this morning, before nine o’clock, DHL was here already with the parcel. The tools are of an excellent quality and I needed all three of them, but within less than 20 minutes the replacement was complete and, against all odds, the MacBook runs again. And to answer your question about the trackpad: mine oozed out by 4mm. But no problem. From the inside the trackpad is held by two thin and short metal stripes, each one fastened by four tiny little screws. Probably the tiniest screws I ever handled, but also here the scPhillips Screwdriver was perfect. Those metal stripes were severely bent bent but could be pressed flat again and I re-mounted them upside down so that they could hold the touchpad perfectly again. Much easier than expected, but obviously a 100% success!
I was given a dead MacBook pro with a battery that was bulging so much that the bottom cover was pushed out almost a half inch. The battery was quite easy to replace using this guide. I bought the battery sold by iFixit. I have only one piece of advice - BUY THE TRIPOINT SCREWDRIVER! I was impatient and removed the tripoint screws by trying to jam in a flathead screwdriver. I got them out, but now the screwheads are stripped a bit. Also, as others have recommended, be sure to calibrate the battery: Turn on the computer and let it drain down to 10%, then charge it uninterrupted to 100%.
Merci beaucoup pour ce tutoriel. Je l’ai suivi et cela m’a beaucoup aidé pour changer la batterie sur mon macbook pro 15” fin 2011.
Pour la version française je modifierais l’avant dernier paragraphe, et je le remplacerais par :
Chargez-la à 100%, puis laissez-la charger encore au moins deux heures. Puis déconnectez le cordon d’alimentation et utilisez votre appareil normalement. Lors de l'avertissement de batterie faible, enregistrez votre travail et laisser votre ordinateur allumé jusqu'à ce qu'il s'éteigne car la batterie est vide. Attendez au moins 5 heures, puis reconnectez l’alimentation et rechargez la batterie à 100% sans interruption.
Bonjour Thierry!
Merci beaucoup pour votre message positif et la proposition de traduction. Je l’ai prise en compte pour remanier le paragraphe. Malheureusement, les caractères d’un paragraphe sont comptés, donc j’ai dû raccourcir une partie.
La prochaine fois, n’hésitez pas à adapter directement la traduction. Pour cela, il suffit de cliquer sur le bouton “Traduire” en haut à droite de l’étape et d’entrer votre traduction.
Merci encore de votre retour et bonnes futures réparations :)
Habs heute gemacht und lief alles optimal! Beim ersten Laden hat der Laptop für das letzte 1% bis 100% 1.5 h gebraucht, denke aber das ist normal! Bald probiere ich die Anleitung zum Wechsel der Kühlkörper aus :)
Danke für die ganzen Anleitungen! Freue mich, dass ich meinen alten mit ein paar Änderungen wieder in einem Topzustand habe :)
G’day folks. This guide and the following comments helped me to get the old swollen battery out. I used a pair of pliers to loosen the screws, as the flat blade screwdriver I had was not enough. The track pad now works again. I did not replace the battery, and the machine seems to be working as normal while running just on mains power, despite warnings on other forums that it would loose performance without the battery. Thanks a lot to all contributors.
Excellente explication. Meilleures amitiés
Step 1 (technically step 9 - replacing the base plate) Apparently one of my screws was a micron or two smaller than the others. This screw belongs to the hole above the optical drive, which is also apparently a couple of microns smaller than the others. It took seven attempts to figure which screw had originally been in that hole; all the other screws were too large, but fitted perfectly everywhere else.
Bizarre much?
Will - Responder
It might be a matter of how the screws are driven in, and not that they're slightly different sizes. When I reassembled my MacBook, a couple of the screws, including the one over the optical drive you mention, were hard to drive in and jutted up a little bit instead of sitting entirely flush. Swapping screws didn't help. The solution was to unscrew them and drive them in at a bit of an angle - perpendicular to the slightly curved surface of the back plate where the screw holes were, instead of fully vertical with respect to the ground the Macbook is sitting on. Doing it that way, the screws were easier to drive in and they all ended up flush in their holes. Didn't matter which screws they were. (I swapped a few around just to check after reading this.)
Andrew Janke -
I had no such screw issues. Either there are differences in manufacturing lots or I just got incredibly lucky during reassembly!
xtophr -
I discovered a great way of organizing the screws. I used an ice cube tray and added the screws in order, keeping the different kinds together. So when it came to reversing the steps, the screw order was an added control step to returning everything in its place.
leonie - Responder
Great advise! Love it! :)
Ririds -
I used to do that and that worked really great until I bumped it by accident and the entire tray went on the rug! I spent the next day sorting things out.
Now I use these:
http://www.sciplus.com/p/50-114-CLEAR-PL...
The lower ones 50 to a package. I mark them w/ blue tape. Often if it's part like the fans, or the optical drive I'll tape the screws into/near the holes where they belong. I did this a lot especially w/ the bottom screws from MBPs until I'd done so many I knew exactly where the longer ones went.
Richard Sato -
I wrapped the screws in a piece of blue masking tape and wrote the number on the little pouch I made. Then I stuck the blue tape pouches on the underside of the case bottom in order.
Roscoe -
I take double-sided tape, put that on a piece of paper, stick the crews to that, and label them.
jelimoore -
Best I've found is a bead sorting tray. They're like $5 at Wal-Mart and they have a lid that seals up and won't let them jump between containers.
maccentric -
I take a sheet of paper, pierce the screws through the paper, take a pen and box the screws and write out what step they belong to.
Nils -
@Will, in my case I had the same result as you did. As a reminder to myself the next time I need to open the computer, I put a dot of white paint on those two screw's head and a very, very thin ring of white on the very edge of each hole, that way I'll know they go into those two holes.
Roger - Responder
Actually the four screws on the bottom were not threaded all the way up. I didn't check to see if the thread gauge was the same on them, but it wasn't until I had about four screws out (I didn't take them out in the order that the bottom all came out first) that I noticed a difference. I then took out the rest of the bottom ones to see if they matched the two that were already out that weren't threaded to the top. They did. So I went under the assumption that those were all bottom screws and when I put it back together everything went fine with no resistance.
So there are three types of screws: Four for the bottom, three long ones as indicated and three others that might be slightly smaller than the bottom ones.
wresnick - Responder
Hi,
Although its more than a year since your contribution, I thought you might be amused to know that it is not just that the screws go in more easily when at an angle, Apple actually drilled and tapped the holes at a 15% angle. I too had tried to drive them in straight. An Apple "genius" - I was in for something else - clarified the design for me. It was done so that the screws lay flush on the angled part of the lower case. Nice design, but since Apple encourages DIY memory and drive changes, they could have mentioned this little ... trap.
H Stahl -
MacBookPro8,2
Intel Core i7, 2,2 GHz, RAM 16 GB
Mountain Lion
May someone help me?
I have installed the second drive with ssd 840 evo, but when I try to copy the file from the new drive to the main hd this in not allowed (errore -36)
Piero - Responder
To my knowledge you can't transfer a single file more than 4gb. I advise compressing to a bunch of rars to split the file size and moving them individually
1982sketcher -
Hey everyone, here's the very best way to PERFECTLY organize your screws AND keep track of the order of the procedure: Get a piece of plain corrugated cardboard and a pen (I like using a Sharpie). For EACH step of the disassembly, draw a simple diagram of the layout of the computer on the piece of cardboard, with dots or Xs where the screws are located. Right after you remove each screw from the computer, poke a hole in the cardboard in its corresponding diagram position with your screwdriver and place the screw in that hole. If there are other non-screw related parts to be removed, you can add notes below each step diagram to remind you of where they go or how they should be placed. This cardboard method is great not only because your screws will not go flying or get mixed up by accident if bumped, but each screw goes EXACTLY back where it came from and you can keep the cardboard as a template for future use if necessary!
- zerø K
zeroK - Responder
a video of these steps
https://www.youtube.com/watch?v=SS9is40C...
julie56 - Responder
These instructions worked great for me. I ordered a replacement battery from Key Power (on Amazon) for my 15" Macbook Pro (mid-2010). Cost was $74 shipped.
Battery came with 3 different screwdrivers to help with installation. I just needed the one size though, since my 2010 seemed to use all the same size screws.
Thanks!
Marcos - Responder
During re-assembling (put the screws back in), it is important to note that the 3mm threaded holes are not completely vertical, but bent a little bit such that the hole direction is rectangular to the tapered surface. The force of the screwdriver must point towards the direction of the hole. Otherwise the screw gets jammed
kusi - Responder
There is a FOOLPROOF WAY TO ORGANIZE ALL SCREWS and other parts removed.
Print the repair guide.
Yes, the actual photo of the bottom of the laptop with the circles around the screws.
When you remove the screw, tape it to the photograph.
You will tape the screw to the exact location that you just removed it from.
Same thing with any part you remove.
splashzoneent - Responder
Thanks Splash!!! I used your suggested method, and it was perfect: kept all my screws, and i was able to, very easily, put them back in their correct place. I greatly appreciated your feedback. Thank you for sharing!!
Tommy Kedar -
Thank you!!! This worked fabulously - even the I.T. people at my workplace were excited as they never thought to do that before. Replacing the battery took about 10 minutes!
nclarke36 -
Worked like a charm! Took less than 20 minutes.
It's Oct. 2015, and the fan cost me about $10. it was the same brand/model...
SUNON MG62090V1-Q020-S99 .
SOME TRICKS -
1- no T6 screwdriver- was careful using needle nose players to loosen 2 screws protruding up, then use a small phillips to push real hard into the T6 slots, SLOWLY turn , also used a small flat head screwdriver (for eye glass repair) was able to grab thread on T6's, made a small mark with screw driver across the top so I could see when it started to turn.
2- no spudger -made one; cut a little strip 1/2" x 1 1/2" of plastic. couldn't get it to slide under plug, there's an edge where plug fits. so lifted old fan out, pulled upward on the plug it popped right out with very little effort. I used my home made spudger to push the new plug into place.
3- download free "Macs Fan Control" This is how I was alerted to the fan not working in the first place. Program shows temperature of all key components in the computer.
cheers- Durango CO!
Dgodrummer - Responder
Watch the video first, read the entire tutorial and all the comments before you start, and spread a white towel on the floor so you can find screws when you drop them. Watch this first -- http://www.youtube.com/watch?v=qiBxhA29e...
kevicoll409 - Responder
The link above is no longer available.
Kristina Graham -
I will be buying a battery from you and using your instructions. I just installed a new CD/DVD using your instructions and 1) I feel like I owe you something and 2) Although more expensive, I have the confidence your battery will work. My current battery is the original with 1399 cycles in 7.2 yrs. A tech buddy had bought me a replacement and I installed it. I had just installed a new OS and the kernel_task went going nuts, using 90% of the CPU. Hours on the phone with Apple did not resolve the issue. On a whim, I put the old battery back in and Voila! But I cannot risk my battery swelling and going south on me. I am also going to buy your installation tools. Yeah, I already have them. But you can never have enough tools…or beer. And you don’t sell beer.
Pete Banks - Responder
The instructions say that I am removing PH00 screws. I found that my MBP, mid ‘12, Retina has pentalobe screws instead!
jsandersonq - Responder
This laptop definitely originally shipped with Phillips screws—but, Apple has been known to replace Phillips screws with pentalobes when one of their devices is brought in for service. Sorry for the rude surprise! Fortunately the correct driver is easy to find nowadays. [Blatant self-promotion alert!] If you support free repair manuals, consider picking one up from iFixit. Good luck!
Jeff Suovanen -
Me, too, and it’s plausible that this machine has been serviced by Apple in the past, replacing the screws as Jeff Suovanen suggests.
iFixit shipped a pentalobe bit with the kit, but it’s too large for the actual screws, so it looks like I now need to get another bit. But what size?
Jeff’s link is to a driver with a P5 bit, and that page links to a P2 screwdriver, but since I don’t know what size I actually need (and I don’t have a micrometer to hand) I’m reluctant to buy two on spec.
Norman Gray -
(The bit in the kit appears to be a P6, so I’m inclined to order a P5 and see what happens)
Norman Gray -
You’re using the wrong repair guide. This guide is for the 2012 NON-Retina MBP. You have a Retina MBP. The stock case screws in the 2012 NON-Retina are all Phillips, just as the guide says.
Steven Wymor -
To keep track of screws, I used the suggestions above by taping a photo of the lower case to a piece of corrugated cardboard and inserting/taping the screws in place. Also, as some have noted, the screws go back in at a slight angle; they are angled toward the center of the unit.
Kristina Graham - Responder
If your vision, like mine, is getting too fuzzy to be able to distinguish between a tiny Phillips screwdriver and a tiny Tri screwdriver, there’s an easy way. With a Phillips (or a Pozidrive) you can get two opposite wings to reflect the light from a lamp or window straight towards your eye at the same time. With a Tri (or Penta) you can only get one wing to reflect at a time, however much you twiddle it.
Alan Waller - Responder
There’s a very easy way to avoid cross-threading a screw thread, any size.
Put the screw into its hole and start by turning it gently, slowly BACKWARDS. When you hear a little “Click!” sound, the male thread has just passed the opening in the female thread and is in exactly the right position to enter into it correctly when you start to turn in the correct forward direction.
Remember, all drivers except hex (Allen key) and TorX need pressure to avoid slipping out and damaging the head. So even when you want to turn it in with LOW moment/torque, keep the CONTACT PRESSURE high.
The keep the pressure on is on point. In my case once I loosened my first screw I thought I could relief my initial pressure. It was a mistake. I was doing the whole thing very slowly as a precaution. That helped me notice that the Phillips screw driver was sliding up out of the screw head. Not being sure why, I put pressure back on the screw driver until almost all the screw was out of the hole. Once out, I examined closely to find out that the threads have some sort of coating. It looks to me like some kind of locktite. Then I understood the importance of keeping the pressure on all the way through. It made me uneasy having to keep so much pressure on such tiny screws, but I found it was the only way to prevent damage to the “slots” on the heads. Anyway, all of them suffered some degree of damage, but I was able to successfully remove them and reinstall all of them back in their original holes.
Martin Mejia -
After reading this page on iFixit several times, I just could not face all the work of replacing the Logic Boards on two MacBookPro 2011s even if I was prepared to pay approx 400 USD (which I wasn’t). Then I read the reviews of a couple of folks who’d stripped down their machines and put their logic boards in the oven and, it worked! I wondered, if I just used my new Steinel Hot Air Tool (heat gun in my language) recently delivered from iFixit, on the logic board in-situ, without removing it? So I removed the battery, hard drive, and RAM and unplugged all the leads I could see WITHOUT removing anything else physically. Then using the 500 degrees set on the gun (setting 2) I ‘played’ the gun over the logic board for about 60 seconds on machine one with the restart problem (plus latterly, not completing start-up). Long story short… it worked! I spent a long time getting the s/w to load, but the commentary is too short to let me relate that part… ping me if I can help you do the same! blackaye@gmail.com
Ian Black - Responder
