Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement, AirPort/Bluetooth Board Assembly: passo 1, imagem 1 %32
    • Pull the camera cable connector straight out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the optical drive opening.
  2. MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 2, imagem 1 %32
    • Use the flat end of a spudger to carefully pry the AirPort/Bluetooth ribbon cable up off its socket on the logic board.
  3. MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 3, imagem 1 %32 MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 3, imagem 2 %32
    • Use the tip of a spudger to pry the four antenna connectors up from their sockets on the AirPort/Bluetooth board.
  4. MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 4, imagem 1 %32 MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 4, imagem 2 %32 MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 4, imagem 3 %32
    • De-route all four antenna cables from their channels in the AirPort/Bluetooth housing.
    • De-route the camera cable from its channel in the AirPort/Bluetooth housing.
  5. MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 5, imagem 1 %32
    • Remove the following two screws securing the AirPort/Bluetooth assembly to the upper case:
    • One 8.6 mm Phillips screw
    • One 3.9 mm Phillips screw
  6. MacBook Pro 15" Unibody Early 2011 AirPort/Bluetooth Board Assembly Replacement: passo 6, imagem 1 %32
    • Remove the AirPort/Bluetooth assembly from the upper case, minding any cables that may get caught.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 488
