Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Remove the lower case to access most of your MacBook Pro's internals.
  1. Remove the following ten screws securing the lower case to the upper case:
    • Seven 3 mm Phillips screws.
  2. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Conclusão
26 outras pessoas concluíram este guia.
These two little plastic clamps on the upper case that snap on/off the lower case broke. I was looking through the store for replacements but I couldn't find any. Does anyone know where I can get these?
hmalissa - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 27
Duração total: 14,937
