Ir para o conteúdo principal
MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
O que você precisa
  1. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: passo 1, imagem 1 %32 MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: passo 1, imagem 2 %32 MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • heat the logo bezel(用吹风机小心的加热LOGO挡板)
    • use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎)
  2. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement: passo 2, imagem 1 %32
    • Put double-sided tape on the back of the bezel(在新的挡板后面贴上双面胶带)
  3. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement: passo 3, imagem 1 %32
    • Install the bezel 把挡板安装到原来的位置
Conclusão
当重新组装你的设备时,请按照说明的相反顺序进行操作。
13 outras pessoas executaram este guia.
n0vem
Membro desde: 08/26/17
607 Reputação
Autoria de 1 guia
60 comentários
I didn't manage to get it off without breaking it so had to order a new one. which was a peal and stick.
mayer - Responder
I don’t understand, when do you need to remove this if it’s not broken already? Are there components underneath that can be replaced/fixed?
Ted -
I have a hairline at the logo baffle if i do not replace it will my screen get harmed?
Please reply ASAP?
Honey - Responder
can u upload the photo, than I can tell u
n0vem -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 46
Duração total: 36,396
