Ir para o conteúdo principal
MacBook Pro 15" Retina Display Mid 2015 SSD Replacement
O que você precisa
  1. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 2, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 2, imagem 2 %32
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 3, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 3, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 3, imagem 3 %32
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, Battery Connector: passo 4, imagem 1 %32
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 5, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 5, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 5, imagem 3 %32
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, SSD: passo 6, imagem 1 %32
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  7. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 7, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 7, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: passo 7, imagem 3 %32
    • Lift the end of the SSD up enough to pass over the speaker directly behind it.
    • Do not lift the SSD too high, or you could damage the contacts or socket.
    • Pull the SSD straight out of its socket on the logic board.
Conclusão
302 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
474.975 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.648 guias
85Comentários do guia
So guys, I got a couple of questions:
1. Is this model (MBP Retina Mid 2015/MacBookPro11,4 ) really upgradable? https://www.datenreise.de/en/macbook-pro... says otherwise.
2. Samsung 850 EVO or Samsung 850 PRO would work with the model mentioned above?
Eduardo Delai Correa - Responder
Yes, it is upgradeable. At the time that article was published there was no drive on the market that would work. Now there is. No the Samsung 850 EVO or Pro would not work. As far as I know OWC is the only one that produces an after market drive that is compatible.
Chris Matlock -
I couldn't find the SSD that Chris mentioned. Would you please point out the exact model?
Jerry Zhong -
It’s the OWC Aura Pro X2, you can get it all the up to 2TB.
Stephen Agnew -
I think you could purchase a pcie to M2 adapter and fit a Samsung 950 Pro in there. 960 Pro is coming out soon though with higher performance.
tonynca7 - Responder
Comentar
Visualizações:
Últimas 24 horas: 68
Últimos 7 dias: 571
Últimos 30 dias: 3,629
Ao todo: 548,247
