Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Use this guide to help you replace a scratched, scuffed, bent or broken bottom panel on your MacBook Pro 15" Retina Display Mid 2015.
  1. Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
    The number of screws listed here is wrong on my model. I had four of the smaller size.
    anonymous 1286 - Responder
    Just to add to my comment above (I can't edit it because it's anonymous), my MacBook Pro is a mid-2015 15in model 2.8GHz (A1398; EMC2881). For the bottom case it uses six 3.1mm screws, and four 2.3mm screws at the clutch/hinge side of the MacBook Pro. I tried using a 3.1mm screw at the clutch/hinge end, as described in the main article, and they don't fit. It has to be four 2.3mm screws.
    WAIT!.. STOP.
    iFixit has had a slew of defective batteries that they will require you take out and return (after gluing them in). Search on: "Battery percentage suddenly drops" here on this site. This process is 50 steps to get the new battery in, and another 50 to put all the parts back. For $199, Apple will do the whole repair, warranty it, and also replace the trackpad and the keyboard (because it's easier for THEM to do).
    Ifixit WILL NOT stand behind defective batteries unless you spend another 4-6 hours swapping in a new one. NOT. WORTH. IT. See posts here (Battery percentage suddenly drops from ~60% to 7%) on frustrated customer’s multiple attempts and class-action lawsuits.
    MFMauceri - Responder
    Thank you for this info, you’ve probably saved a lot of time, and hassle (myself included, if I end up going through with this repair).
    Andrew Poindexter -
    The instructions below have you basically taking ALL of the guts out of case. I’ve been doing my own apple repairs since before ifixit was a thing and this one is a handful. My battery was swelling and I wanted to remove it before it burst or bent the case so I took it out without having a replacement and it occurs to me that aside from using the solvent (liquid) to remove the adhesive, you could probably do this only taking the trackpad ribbon out. I have mine reassembled now and will research the best battery to buy but I think installation will take about 5 minutes. See if you can slip a plastic gift card under the battery and wag/saw the adhesive out without the solvent before you go through all of this. It might work. Note, don’t bend or put too much stress on the battery and certainly don’t puncture it…
    br1ansk - Responder
    I’m having a problem trying to get the screws off. I have a set of pentalobe screwdriver set. I found one screwdriver that fits perfectly on one set of screws, but I am unable to unscrew it. I tried using some force pushing the screwdriver into the screw, but nothing happens. Any suggestions?
    henry_k_wong - Responder
    All the screws on mine are the same length for some reason.
    ccfman2004 - Responder
  2. Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro. Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange). During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips. During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
    pretty hard to put it back, so I just remove the clips on the upper case....
    jamiegan835 - Responder
    The trick to putting it back on is to guide your fingers to the same level as the clips, and then when you put the case down move your hand from the left side of the case to the right side of the case; applying pressure when you reach the area where the clips are.
    Aaron Freidus - Responder
    You don't have to take so many steps.
    santa1234 - Responder
    I have magnets- is this the wrong guide?
    Benjamin Jones - Responder
Conclusão
19 outras pessoas concluíram este guia.
Andrew Optimus Goldheart
Membro desde: 17/10/2009
458.998 Reputação
410 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
132 Membros
13.037 Guias de autoria
Do we need two different screw drivers for this or is the recommended one enough?
Jamey Rassweiler - Responder
You need the recommended one for the lid an a torx T5 for the screws inside
Oros -
hello i have a 2015 15” macbook pro nut i want them all custom to me so scraped off the paint to be clear back. ive seen many “clear looking stickers but they mostly look $@$*!&. have you herd of any copany selling a clearback housing and can only find stickers do you knaw any sites delling vlear hpusings?. the only other thing i can think of if have a friend #D print in clear and polish it till turns clear any ideas? i also wany yje top case vlrar slso but oe thing at a time
jae.good - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 26
Últimos 7 dias: 216
Últimos 30 dias: 1,032
Duração total: 35,358
