Ir para o conteúdo principal
MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement
O que você precisa
  1. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: passo 2, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: passo 2, imagem 2 %32
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: passo 3, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: passo 3, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: passo 3, imagem 3 %32
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
Conclusão
30 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
493.488 Reputação
407 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
138 Membros
16.926 Guias de autoria
3 comentários
Do we need two different screw drivers for this or is the recommended one enough?
Jamey Rassweiler - Responder
You need the recommended one for the lid an a torx T5 for the screws inside
Oros -
hello i have a 2015 15” macbook pro nut i want them all custom to me so scraped off the paint to be clear back. ive seen many “clear looking stickers but they mostly look $@$*!&. have you herd of any copany selling a clearback housing and can only find stickers do you knaw any sites delling vlear hpusings?. the only other thing i can think of if have a friend #D print in clear and polish it till turns clear any ideas? i also wany yje top case vlrar slso but oe thing at a time
jae.good - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 110
Últimos 30 dias: 622
Duração total: 56,372
