Introdução
Fans can be such blowhards, except when they blow out. Use this guide to help you replace a damaged, broken, or faulty right fan.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. On reassembly, connect this end first as it does not flex.
In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
52 outras pessoas concluíram este guia.
11 comentários
Great guide! It took me 45 minutes to replace my old and loud right fan. Thanks for the guide!
Installed the new fan but it's not running. Other fan is running. Any ideas?
done! thank you fixit!!!!
