Ir para o conteúdo principal
MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement, Logic Board Removal: passo 1, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement, Logic Board Removal: passo 1, imagem 2 %32
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
  2. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 2, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 2, imagem 2 %32 MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 2, imagem 3 %32
    • Peel back the tape covering the top of the keyboard ribbon cable connector.
    • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the flat end of a spudger to push the keyboard ribbon cable out of its socket.
  3. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 3, imagem 1 %32
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up out of its socket.
  4. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 4, imagem 1 %32
    • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
  5. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 5, imagem 1 %32
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket.
  6. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 6, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 6, imagem 2 %32
    • Use the tip of a spudger to flip up the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  7. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 7, imagem 1 %32
    • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
    • The location of this screw may vary between models.
  8. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 8, imagem 1 %32
    • Remove the following six screws securing the logic board to to the upper case:
    • One 3.1 mm T5 Torx screw
    • One 2.5 mm T5 Torx screw
    • One 5.5 mm silver, raised-head T5 Torx screw
    • Two 5.7 mm T5 Torx screws
    • One 3.8 mm silver T5 Torx screw
  9. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 9, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 9, imagem 2 %32
    • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
    • You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
    • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
    • Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board, and then remove the logic board and MagSafe board together.
  10. MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 10, imagem 1 %32 MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 10, imagem 2 %32 MacBook Pro 15" Retina Display Late 2013 Logic Board Assembly Replacement: passo 10, imagem 3 %32
    • Remove the logic board assembly from the MacBook Pro.
    • While the logic board and fans are removed, use a can of compressed air and a soft, non-static brush to remove dust and other debris from the upper case and the logic board, particularly from the fan exhaust openings along the rear edge of the upper case.
    • When reinstalling the motherboard, make sure all cables, and the two rubber heat sink/fan covers, are visible and not trapped under the motherboard.
    • Second photo, clockwise from top: battery, right speaker, keyboard backlight, AirPort/camera, display, microphone, left speaker, keyboard, and trackpad.
Conclusão
4 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
493.322 Reputação
407 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
140 Membros
16.861 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,281
