Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
  1. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. Este passo não foi traduzido. Ajude a traduzi-lo
    Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  4. Este passo não foi traduzido. Ajude a traduzi-lo
    Peel back the warning label covering the battery connector.
    • Peel back the warning label covering the battery connector.
  5. Este passo não foi traduzido. Ajude a traduzi-lo
    Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board. Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  7. Este passo não foi traduzido. Ajude a traduzi-lo
    Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board. Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
Linha de Chegada
46 outras pessoas concluíram este guia.
Sam Goldheart
Membro desde: 18/10/2012
414.380 Reputação
547 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
126 Membros
11.884 Guias de autoria
Where is the left fan in the pic? Please tell me I don't need to remove the fan before doing the replacement.
Ethan - Responder
I see that for all the guides for all the MBP models with solid state storage, the battery is disconnected before the solid state storage is removed. Why?
Traditional hard drives and SSDs don't have to have their batteries disconnected before removing...do they?
Hobowan Kenobi - Responder
You should remove it. It's just good practice when doing anything internal on any laptop.
farleyaustin -
这个ssd的接口是什么呢?我应该购买什么型号的ssd能适配这个,怎么筛选?
lizhao - Responder
Can I update my SSD to 1TB from 512GB? RMBP 2013 Early
FAN Guoxing - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 29
Últimos 7 dias: 194
Últimos 30 dias: 719
Duração total: 81,851
