Ir para o conteúdo principal
MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement
O que você precisa
  1. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Battery: passo 1, imagem 1 %32
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Memory Door: passo 2, imagem 1 %32
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
  3. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 3, imagem 1 %32
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Upper Case: passo 4, imagem 1 %32
    • Remove the two Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 5, imagem 1 %32
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 6, imagem 1 %32
    • Remove the four Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 7, imagem 1 %32
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 8, imagem 1 %32
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 9, imagem 1 %32
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
  10. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 10, imagem 1 %32
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Display Assembly: passo 11, imagem 1 %32
    • Disconnect the two antenna cables attached to the Airport Extreme card.
    • The white antenna cable connects to the left side of the Airport Extreme card.
  12. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 12, imagem 1 %32
    • Deroute the Airport antenna cables from their channel in the left speaker.
  13. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 13, imagem 1 %32
    • Disconnect the iSight, inverter, and left fan cables from the logic board by gently pulling in the direction of each cable.
  14. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 14, imagem 1 %32
    • Disconnect the display data cable from the logic board.
  15. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 15, imagem 1 %32
    • Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
  16. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 16, imagem 1 %32
    • Support the display with one hand while removing the following 3 screws:
    • Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
    • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
  17. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 17, imagem 1 %32
    • Grasp the display assembly on both sides and lift it up and out of the computer.
  18. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Rear Display Bezel: passo 18, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Rear Display Bezel: passo 18, imagem 2 %32
    • Remove the two 5 mm Phillips screws from the lower left and right corners of the display (two screws total).
  19. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 19, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 19, imagem 2 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 19, imagem 3 %32
    • Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
    • Do not insert your spudger between the plastic strip and the rear bezel.
    • With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
    • Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
  20. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 20, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 20, imagem 2 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 20, imagem 3 %32
    • Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
  21. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 21, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 21, imagem 2 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 21, imagem 3 %32
    • Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
    • Rotate your spudger toward the rear bezel to separate it from the front bezel.
    • If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
  22. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 22, imagem 1 %32
    • Lift the rear bezel by its bottom edge and rotate it away from the display assembly to separate the top edge.
    • Remove the rear display bezel from the display assembly.
  23. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Display Inverter: passo 23, imagem 1 %32
    • The display inverter is a very thin and delicate circuit board that is easily broken. Use caution when handling.
    • Carefully lift the inverter board out of the clutch cover.
  24. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 24, imagem 1 %32
    • Disconnect the LCD backlight from the inverter by pulling its connector away from the inverter board.
  25. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 25, imagem 1 %32
    • Be cautious to not put any strain on the inverter cable ground loop, as it is a very thin and delicate wire.
    • Disconnect the inverter cable by pulling its connector away from the socket on the inverter.
  26. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Clutch Assembly: passo 26, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Clutch Assembly: passo 26, imagem 2 %32
    • Remove the pieces of yellow kapton tape from the bottom left corner of the display.
    • Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
    • The adhesive connecting these straps to the display is very strong. An edged tool is helpful to separate the adhesive while you peel the straps off.
    • Remove the piece of tape securing the camera cable to the LCD.
  27. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 27, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 27, imagem 2 %32
    • Remove the pieces of tape covering the display data cable and camera cable connectors.
    • Carefully peel the camera cable off the foam tape along the top edge of the LCD.
  28. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 28, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 28, imagem 2 %32
    • Gently pull the camera cable away from its socket on the camera board.
    • Pull the display data cable connector away from its socket on the LCD.
    • Pull both cables parallel to the face of the logic board.
  29. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 29, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 29, imagem 2 %32
    • If you have a Core Duo machine, refer to picture 1 and remove three Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
    • If you have a Core 2 Duo Model A1211 machine, refer to picture 2 and remove two Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
  30. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 30, imagem 1 %32
    • Remove the small Phillips screw from behind the display data cable.
    • Remove the small rectangular steel bracket by sliding it away from the right clutch hinge.
    • If you have a Core 2 Duo Model A1211, there is no steel bracket. Simply remove the screw and continue to the next step.
  31. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 31, imagem 1 %32
    • Remove three Phillips screws attaching the clutch assembly to the lower edge of the front display bezel.
    • The inverter cable ground loop is a very thin and delicate wire. Work gently.
  32. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 32, imagem 1 %32 MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 32, imagem 2 %32
    • Push the open edge of the clutch cover away from the left clutch hinge to pop it off the clips attaching the two parts.
    • If necessary, repeat this process for the right side of the clutch assembly.
    • Remove the clutch assembly from the front display bezel.
  33. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Inverter/Camera Cable: passo 33, imagem 1 %32
    • De-route the inverter/camera cable from the left clutch hinge and remove it from the display.
  34. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement, Left Clutch Hinge: passo 34, imagem 1 %32
    • Remove the four T6 Torx screws securing the left clutch hinge to the front display bezel.
  35. MacBook Pro 15" Core Duo Model A1150 Left Clutch Hinge Replacement: passo 35, imagem 1 %32
    • Remove the left clutch hinge from the front display bezel.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 9,437
