Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Accessing the RAM is easy.
O que você precisa
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connector.
222 outras pessoas executaram este guia.
Um comentário
Really easy to install RAM on Macbook Pro 15'' Model A1226!!
I had 2GB of RAM (1GB and 1GB), so when I read this tutorial I decided to buy one ram of 2GB 667Mhz and It is working great (now I've got a total of 3 GB). I'm willing to install up to 6 GB with this same tutorial. Recommended!
