Ir para o conteúdo principal
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement
O que você precisa
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, Battery: passo 1, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, Battery: passo 1, imagem 2 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, Battery: passo 1, imagem 3 %32
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
    ColmillodeChile - Responder
    Besides using WD 500GB models, are the WD 640GB and WD 750GB (the 9.5mm thickness model) good to go for? I am still considering as I have heard from other websites on the computer does not draw enough power to power up the 640 and 750 as it has the clicking sound and the rainbow keeps appearing. Anyone has install one before yet?
    Please advice. Appreciated! Thanks a million to all the Mac gurus out there!
    Danny Lim -
    Citação de ColmillodeChile:
    What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
    Adrian - Responder
    No, that's nonsense
    max damage -
    Citação de Adrianthomaspre:
    Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
    Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
    Adrian - Responder
    The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
    Doug - Responder
    Citação de Doug:
    I think you may have commented on the wrong page. This page only has 3 steps, and the screws are removed in step 2, not 3.
    (MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement)
    Don - Responder
    I'm not sure how the user notes get attached to the various procedures here, but my comment does seem to show up properly when viewing the steps for Hard Drive Replacement. However, the number of the step may be off if viewed as part of another procedure.
    Citação de Don:
    Doug - Responder
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, RAM Shield: passo 2, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, RAM Shield: passo 2, imagem 2 %32
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
    These screws are different from the rest, they should be kept separate from the others.
    foregoing-celery - Responder
    Replacing RAM on an A1226: The instructions said Phillips #00, but the screwdriver that fit the RAM Shield screws for me was a Phillips #0.
    dlyons - Responder
    Concur, my screws were Phillips #0 as
    Lee Haelters - Responder
  3. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, Upper Case: passo 3, imagem 1 %32
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
    Keep these two Philips screws separate. The screws are approximately 0.5mm shorter in length. When using one or two of the other longer screws in the battery compartment when reassembling, the lid will not open because the screw(s) do yam the lid button.
    Peter van Nes - Responder
    I had a logic board replaced by Apple (bad nVidia GPU), and believe it or not the Apple tech mixed up the screws. My latch did not work as good until I discovered and swapped the misplaced screws.
    madmaxmedia - Responder
    No believe it or not about it! I had same board replacement job done, and a screw was angled and crossthreaded, and the memory cover was hacked into place with insulating sheet lifted and crumpled.
    Lee Haelters -
    I removed the memory here as you would normally if you were changing it.
    Mike Matthias - Responder
    Use #00 phillips bit
    Jace - Responder
  4. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 4, imagem 1 %32
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  5. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 5, imagem 1 %32
    • Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
    If you are using a muffin pan to keep removed parts separate (a method I recommend highly), note that Steps 5, 6, and 7 involve removing the same size screw—and thus you can put them all in the same pile. This is unlike just about every other part you will remove during this procedure.
    Matt McCaffrey - Responder
    Using shot glasses!
    peterbcpa -
    If you are a mac newbie like me take care when you reassemble not to insert a screw in the DVI display port screw holes (shame). I cannot manage to get it out anymore.
    tai manu - Responder
    I did the same thing once, and eventually got it out. Try tweezers, a screwdriver, magnets, holding the MBP on its side so gravity is working with you, etc. Eventually the little bugger will come out, you just have to keep working at it.
    madmaxmedia -
    It would be a good idea to put some sticky tape on those two DVI display port holes, so that you never make the mistake to insert (when reassemble) any of the screws!
    genik - Responder
    RE: Misplaced Screws in the DVI port, I was upgrading an early 2008 MacBook Pro with an SSD to get some more life out it, and sure enough, misplaced one of these small screws into the DVI port upon reassembly. Screwdrivers, shaking, gravity... nothing worked. UNTIL I went to my dad's house and his super-comprehensive workbench, where he found a small, high-pull magnet and the little bugger flew right out. Refrigerator magnets won't cut it, you will need a more powerful magnet, such as these: http://www.kjmagnetics.com/products.asp?...
    Hope this helps someone... it was an easy solution to a frustrating problem
    John Lee - Responder
  6. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 6, imagem 1 %32
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  7. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 7, imagem 1 %32
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  8. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 8, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 8, imagem 2 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 8, imagem 3 %32
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
    • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
    • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
    The clips above the DVD slot (below the deck palm rest) are an absolute bear. They're hard to get released, and even harder to get back locked when you reassemble. (I've read to tilt the deck toward you when reassembling, inserting the front edge first, and press about an inch back from the edge to get all the front clips locked first before lowering the rest (back) of the deck.) No success for me yet, best of luck.
    sonofray - Responder
    I thought these two videos did an excellent job of showing the technique of removing and replacing the drive.
    MacBook Pro/PowerBook Keyboard Replacement (Part 1 of 3):
    http://www.youtube.com/watch?v=jUonF9OSv...
    MacBook Pro/PowerBook Keyboard Replacement (Part 3 of 3):
    http://www.youtube.com/watch?v=JWeFXWXpp...
    After watching that, I had the keyboard replaced in 2 minutes.
    Chris -
    the technique you describe of putting the front down first, is exactly what I did and it worked well
    dillonsavard -
    Those clips on the front edge are very challenging. I have a set of nylon pry tools that are for taking apart car dashboards without scratching the vinyl or plastic. I was able to get a long one in from the side and twist it which freed the clips without damaging the plastic on the upper case or the aluminum on the lower case.
    Putting it back together presented another challenge. When I first re-assembled it I think I pushed too hard over the DVD slot and accidentally bent the metal down. I was able to bend it back up using a thicker part of those same nylon pry tools, and then i was able to get it snapped back down successfully. Had I known this would happen, I would have just put the nylon tool in the slot to reinforce the metal as I was snapping the case back down.
    Nick - Responder
    As everyone has said, the front clips by the DVD can be really tight. Use the spudger to pry the top and bottom halves apart. Slow work it in from one side to separate the top and bottom.
    When reassembling the case, work the front clips by the DVD drive back in first. Once you slide them back in, the rest of the case fits easily.
    Ted Wise - Responder
    i've used an old atm card, it works fine.
    rotarypot - Responder
    I had a lot of trouble with getting those clips to lock in place again when reassembling. The way I eventually did it was to wedge something into the front of the CD/DVD slot so that I wouldn't warp the laptop casing. I used the end of a pen; when wedged in the tip of the pen was the right height to not support the casing above and below the CD/DVD slot and not allow it to warp.
    I simply ensured the pen was aligned with one particular clip, lifted the laptop slightly, and squeezed the top and bottom edge of the laptop casing very firmly at that point. Each clip clicked in quite easily doing it this way. Just remember to move the pen (or whatever you are using) along to whichever clip you are clicking in.
    David - Responder
    You're on the right track David. But what works really good is something that gets more surface area contact than the pen--I carefully insert a stack of 3" square post-it notes about 3/8" into the slot. And because they're stacked, you can easily add/subtract post-its to get as tight a fit as possible. Then, assuming you have everything lined up, use quite a bit of downward pressure. You should hear a few snaps as the clips reseat.
    Citação de David:
    John Kassler Niemann - Responder
    John, I didn't think of that. But yeah you are right, it would give it a lot more support.
    David - Responder
    I have none of the problems above just was very careful, but inserting the palm rest in first does most of the work , gently does it looking at the alinement of the clips as you go straight in she goes!
    swissgrip - Responder
    I would agree with everyone that the clips above the DVD drive are very temperamental. They came off easily for me but were a pain getting to clip back in place correctly.
    Make sure you have the front clipped on securely before screwing the case back together otherwise the lid will not close properly.
    Nicolas - Responder
    I have taken apart quite a few laptops but this is my first Mac. This confirms my statements, to anyone that will listen, that these are the most "exquisite" machines ever produced. I just performed these HDD Replacement steps and with appropriate fear and trepidation popped the clips off. It would have been very helpful if someone had mentioned that they come straight up. I wasn't sure so I wiggled and (carefully) pried with the spudger until one of them went "POP". The credit card idea was helpful but my card was pretty soft so I didn't dare use it with too much force. When I got the top cover loose I just leaned it back against the screen so as not to take a chance on damaging the cable. Reassembly was according to the notes, but again the spudger was perfect if inserted into the drive slot (careful on the felt!) to support the base of the clips. Thanks to all for the notes. BTW; Prayer helps!
    mikedotten331 - Responder
    There is a fifth plastic clip between the IR sensor and the screw hole. (ie. 1 cm left of the IR sensor)
    On the top of the case mark the center of each of the four clips that are over the CD slot and the one clip to the left of the latch with a pencil. When re-installing the top case apply pressure over the clip to the left of the latch until you hear a snap. For the four clips over the CD slot, upend the entire case. Then insert the flat end of the spudger into the CD slot under the center of each clip. Apply pressure from the top of the case while providing support with the spudger in the CD slot until the clip snaps in. This will minimize the chances of bending the CD slot which would prevent CDs from ejecting.
    danno - Responder
    Take care reassembling new the DVD drive. It's easy to bend the top piece of metal down (the one that engages the clips) and your DVD can get stuck occasional ejecting. Very annoying. Maybe give it a little prophylactic bend upward. I placed a blunt letter opener in the slot and torqued it, while applying downward pressure from the top deck... This allowed the clips to engage nicely without bending this piece down.
    davidkkim - Responder
    I use the iSesamo tool to loose the clips, its a very good tool for this and many other things (I don´t work for iSesamo or iFixit hehe).
    araujogac - Responder
    i've used both of my inch nails, it works fine as well. no trouble to report.
    Caroline Masson - Responder
    i used a pry tool i had left over from replacing the screen on my iphone, any flat stiff item, like a credit card would work. watch the youtube video linked above, http://www.youtube.com/watch?v=jUonF9OSv..., skip ahead in the video to 4:57 where you see her use a pry tool. I had no problem separating and reassembling this section. Only issue i had was the two screws in the battery area. Only one of them would grab, so I left the other one out.
    owenmhv - Responder
    Here is an additional video showing how to remove the cables for both the left and right fans. At time 2:00 in the video he starts to work on the left fan. This video will help prevent you from attempting to detach the cables incorrectly.
    http://www.youtube.com/watch?v=apn3j3mAR...
    owenmhv - Responder
    I've opened these up many, many times, and by far the easiest method I have found to disengage the front clips is as follows:
    Lift up the top case by the rear corners near the hinge, keep lifting so the top case is tilting towards you. You will feel some resistance, but keep lifting and you will hear the clips disengage with a 'snap'. Doing it this way should not bend the top case metal or loosen the spacing between the top case metal and plastic trim. The clips will not break, they will still engage when you put the top case back on.
    It basically takes me 5 or 10 seconds to take off the top case now, and the case goes back on nice and tight as before.
    YMMV and all that, but that's my experience.
    Thank you for all the advance warnings, I had no issues with replacing the case. It just snapped into place with a little help from the spudger.
    acuella - Responder
    You're welcome! I was the one who added the spudger tips, as I had a devil of a time making the DVD drive clips snap back into place without one when I followed this guide.
    CaptFrost -
    Hello,
    I didn't have much problems reassembling the MacBook. Thanks a lot!
    For the hard reassembly part with the clips: I pushed quite hard with both thumbs directly over the place where the clips are. You need to figure out exactly where they are, but it worked well.
    I repeat it to make it clear: I pushed from the top on the location under which the clip sat, with two thumbs after having checked that the lid was well in place.
    My tools were one spudger and a basic tech toolkit from iFixit.
    Thanks a lot!
    momogingins - Responder
    I had not problem easing GENTLY the top case from the computer even around the DVD but I didn't understand how easy it was to disconnect the top case from the mother board. TAKE CARE HERE. It will make reassembly much easier it YOU get to disconnect the plug. See my note on step nine
    reb - Responder
  9. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 9, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 9, imagem 2 %32
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
    • Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
    • Remove the upper case.
    If you does not have the spudger, use the Dremel to file a wooden piece
    (Chinese stick maybe) to transform in a spatula. Works fine for me
    If you don't have the magic "spudger," try using a plastic (eating) knife.
    jpkjpkjpk - Responder
    I read that you can actually also use the corner of a credit card. I didn't have a spudger and this worked perfectly for me. If you hold the card quite close to the corner and it has just the right amount of flex.
    David - Responder
    You may be able to unplug the ribbon connector by lifting each end of the tape.
    MrSafety - Responder
    Where can I get the cable from step 9 above?
    just broke it!
    Derry Manley - Responder
    That cable is attached to the upper case. It can be found here for the A1226 and here for the A1260.
    Andrew Bookholt -
    To unplug the cable, pull the black connector straight up from the logic board.
    Robert MacLeay - Responder
    These are instructions for the right Fan. Step 9 mentions the hard drive not the right fan.
    karen - Responder
    I didn`t need to unplugged the cable to change the right fan. As Karen wrote above, it is for a fan to change not necessary.
    I chose not to disconnect this ribbon cable. I used a chopstick to prop open the front panel; just gently place in lower right corned of case and upper right corner inside the top panel. Saves the risk of disconnecting.
    jimmora - Responder
    I didn't look well before the plug connecting top case to motherboard (see my note in step 8). When it came time for assembly it took a while for me to figure out when the plug connected in the motherboard. Take care on step 8 so that YOU have to make the disconnection in step 9. Then reassembly on this step will be much easier.
    reb - Responder
    Step 9, 2007 Mac Book Pro right fan replacement. It’s not necessary to disengage the keyboard ribbon, you can just tilt the upper shell back and support it against the screen. Be sure not to put tension on the ribbon and to check that the ribbon “plug” is seated securely on the base before reinstalling the top shell.
    These instructions were really great. For $15 I got a used fan off eBay and a Torx T6 driver and Phillips 00 driver from the hardware store. Thanks also for the comment about marking where the plastic clips are by the DVD and IR slot with pencil. When reassembling I slotted a piece of wood (kebab skewer) into the DVD slot and pressed down on the pencil mark with the eraser end of the pencil.
    My 10 year old MacBook Pro is going strong. Thanks for these very much. It was fun to do as well.
    Kirsten - Responder
    Hello, I have a MacBook like this but I have seen that in the part of the RAM on the right there is an elongated chip, I don't have it, that could cause the problem of no connection, what is the name of that chip, thank you
    Trepas - Responder
  10. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, Left Fan: passo 10, imagem 1 %32
    • Use a spudger to disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
    This video will show the proper removal of the left fan and cables, forward to 2:00
    first part of the video is removing the right side fan.
    owenmhv - Responder
  11. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 11, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 11, imagem 2 %32
    • Disconnect the left fan and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
    • Pry up from beneath the wires.
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
    My computer had a piece of tape over the fan and light sensor cables connections. Don't forget to replace it...like I did.
    Holly S - Responder
    I just broke the clip on the board that the light sensor goes into (no more light sensor). The picture is not clear on HOW the cables are connected to the board. I lifted the fan cable from the cable side rather than the connector side and removed the cable without breaking the connector on the board.
    jchapman - Responder
    Take note of the orientation and wire colors before removing the fan and replacing. My iFixit replacement came with the connector and wires twisted upside down and I didn't realize I was trying to put it in the wrong way. It was hard to tell because it's black.
    I did the same thing jchapman did - only I broke the connector ALSO pried up and broke the fan connector. I found a very, very patient man at a computer repair shop that re-soldered the fan connector for me so I would have a left fan. I didn't even want to replace the fan, just clean the heat sink (which I didn't end up doing). $180 later, I now have left fan and ambient light sensor. Next repair I will follow step-by-step, referring to guide as I go and not try to remember what I read!
    Debi - Responder
    Make sure to properly re-seat the new fan's cable.
    jonathanbruck - Responder
  12. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 12, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 12, imagem 2 %32
    • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
    • Lift the fan up; carefully peel up the tape that secures the fan to the heat sink as you go.
    No mention when instaling the NEW fan, of what to do about the tape that secures the fan to the heat sink. The new fan didn't come with any tape, but the exiting black tape has metal contacts on the underside that appear to line up with metal contacts on the heat sink. I just carefully put the old tape back on the new fan, lining it up with the metal on the heat sink. I hope that was the right thing to do! Works fine. I recommend iStat widget to see your fan's rpm's. Helped me confirm that my old fan was caput (zero rpm's while right was at 2000rpm's) and the new fan reads 2000rpm's same as the right (and I can hear the new fan, but not nearly as loud as the old fan before it stopped altogether).
    dillonsavard - Responder
    What about replacing heat sink grease?
    375GTB - Responder
  13. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, ExpressCard Cage: passo 13, imagem 1 %32
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  14. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 14, imagem 1 %32
    • Disconnect the two antenna cables attached to the Airport Extreme card.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
    on my computer there are three cables here: (from l to r) black, gray, and blue
    blintrick - Responder
  15. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 15, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 15, imagem 2 %32
    • Remove the single black 4mm T6 Torx screw located just above the Airport Extreme card.
    • Remove the metal bracket that was securing the Airport Extreme card.
  16. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 16, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 16, imagem 2 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 16, imagem 3 %32
    • Lift the Airport Extreme card up and slide it out of its connector.
    • Deroute the Airport antenna cables from their channel in the left speaker.
    • Peel up the orange hard drive cable from above the ExpressCard cage.
  17. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 17, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 17, imagem 2 %32
    • Use a spudger to disconnect the speaker cable from the corner of the left I/O board.
    • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
    Some might find it easier to remove the speaker assembly out of its housing by first disconnecting the inverter cable at this point (Step 19 below),
    peteragries - Responder
  18. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 18, imagem 1 %32
    • Disconnect the large gray and black power cable from the left I/O board.
  19. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 19, imagem 1 %32
    • Use a spudger to disconnect the inverter cable from the corner of the left I/O board.
  20. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 20, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 20, imagem 2 %32
    • Remove the following 5 screws/standoffs:
    • Four black 4 mm T6 Torx screws securing the left I/O board to the lower case.
    • One 4 mm standoff located between the audio jacks.
    • Lift up the right side of the left I/O board and slide it out of the computer.
  21. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 21, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement: passo 21, imagem 2 %32
    • Remove the following four screws:
    • One 3.1 mm at upper right.
    • One 4.9 mm at upper left.
    • Two 2.2 mm along the bottom.
    • Lift the left I/O board off the ExpressCard cage.
  22. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left I/O Board Replacement, Left I/O Board: passo 22, imagem 1 %32
    • Disconnect the short left I/O board cable.
    • Left I/O board remains.
Conclusão
52 outras pessoas executaram este guia.
Um comentário
Just successfully completed this repair. The guide is absolutely spot on with very clear high resolution pictures. I was working very carefully through each step and had no issues at all throughout the process until the very end when I couldn't find the last screw for the ram cover. Luckily it was stuck to the magnetic MagSafe charger port on the side of the I/O board!
I personally would rate this as a moderate repair instead of a difficult one as there is no specialist skills required like soldering. Thanks again!
Franco - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 26
Duração total: 58,963
