Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Battery Replacement
O que você precisa
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Battery Replacement, Battery: passo 1, imagem 1 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Battery Replacement, Battery: passo 1, imagem 2 %32 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Conclusão
80 outras pessoas executaram este guia.
3 comentários
Help! After installing new battery, one of the tabs does not close totally, leaving a bit or orange showing, and mouse pad is hardly operational. Cannot seem to get it to install completely. Put old battery back in to double check and its fine. Tried new battery 3 times to no avail!! Any tips?? Thank you!
Carolyn Smith - Responder
Mmm, I think in two options:
1. The new battery has some imperfections and don´t met the official dimensions.
2. If the new battery is used, had an overheat and that caused a variation in its dimensions.
Sorry if I can´t help you more
ColmillodeChile - Responder
This has to be the easiest iFixit tutorial ever! Haha
maxime.abbey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 62
Duração total: 52,685
