Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
All you need to remove the battery is your fingers!
O que você precisa
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
80 outras pessoas executaram este guia.
3 comentários
Help! After installing new battery, one of the tabs does not close totally, leaving a bit or orange showing, and mouse pad is hardly operational. Cannot seem to get it to install completely. Put old battery back in to double check and its fine. Tried new battery 3 times to no avail!! Any tips?? Thank you!
Mmm, I think in two options:
1. The new battery has some imperfections and don´t met the official dimensions.
2. If the new battery is used, had an overheat and that caused a variation in its dimensions.
Sorry if I can´t help you more
This has to be the easiest iFixit tutorial ever! Haha
