Introdução
Upgrade or replace the SuperDrive (requires a slim drive).
Peças
- MacBook/MacBook Pro 15" 6x SuperDrive
- MacBook Pro 15" (Models A1150/A1211) 4x SuperDrive (Used)
- MacBook Pro 15" (Models A1150/A1211) 6x SuperDrive (Used)
- 9.5 mm PATA Optical Bay SATA Hard Drive Enclosure
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
79 outras pessoas concluíram este guia.
