Ir para o conteúdo principal
Vídeo de Apresentação
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua MacBook Pro 14" Late 2023 (M3 Pro and M3 Max), use o nosso manual de serviço.
  1. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 1: passo 1, imagem 1 %32 MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 1: passo 1, imagem 2 %32
    • Apple APL1203/339S01320 M3 Pro 12-core applications processor w/ 18 GB memory
    • Apple APL109H/343S00652 power management
    • Apple APL109H/343S00653 power management
    • Kioxia K5A3U08299 128 GB NAND flash
    • Texas Instruments SN25A12 USB type-C controller
    • Likely Parade Technologies PS190 DisplayPort-to-HDMI converter
    • Likely Apple U0KSS1-L2 ThunderBolt controller
  2. MacBook Pro 14" Late 2023 M3 Pro Chip ID: passo 2, imagem 1 %32
    • Genesys Logic GL9755A card reader controller
    • Apple 338S00600-A0 power management
    • GigaDevice GD25Q80E 1 MB serial NOR flash memory
    • Winbond W25Q80DVUXIE 1 MB serial NOR flash memory
    • Renesas RAA225702B DC-DC converter
    • Analog Devices LT8642EV-1 10 A / 18 V synchronous step-down regulator
    • Texas Instruments TPS62180 6 A synchronous buck converter
  3. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2: passo 3, imagem 1 %32 MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2: passo 3, imagem 2 %32
    • Renesas RAA489901A5 battery charger
    • Texas Instruments SN012776B0 audio amplifier
    • Kioxia K5A3UN0975 128 GB NAND flash
    • Apple APL109G/343S00649 power management
    • Apple APL109G/343S00650 power management
    • Cirrus Logic CS42L84A audio codec
  4. MacBook Pro 14" Late 2023 M3 Pro Chip ID: passo 4, imagem 1 %32
    • Winbond W25Q64NEXGIG 8 MB serial NOR flash memory
    • Winbond W25X40CLUXIG 4 Mb serial NOR flash memory
    • Texas Instruments LP8548B1 LED backlight driver
    • Renesas RAA209100B1 DC-DC converter
    • Renesas RAAxxx501C DC-DC converter
    • Texas Instruments REF3325 2.5 V voltage reference
  5. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2 - Connectivity: passo 5, imagem 1 %32
    • Likely USI 339S01093 WiFi/Bluetooth module
  6. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2 - Sensors: passo 6, imagem 1 %32
    • Likely Bosch Sensortec accelerometer and gyroscope
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 108
Últimos 30 dias: 565
Duração total: 8,243
