Ir para o conteúdo principal
MacBook Pro 13" Unibody Mid 2012 Lower Case Replacement
O que você precisa
  1. MacBook Pro 13" Unibody Mid 2012 Lower Case Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Mid 2012 Lower Case Replacement: passo 2, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Lower Case Replacement: passo 2, imagem 2 %32
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
Conclusão
85 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
502.810 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
7 comentários
When purchasing a new bottom panel, do any of the stickers or pads have to be transferred to the new part? How?
Matthew Parrott - Responder
This is the instructions on how to just remove the bottom cover to access other components. The part is sold here on iFixit for $99 and looks to include the rubber feet.
Cwoodyard -
Where can I get a new backover?
SkyGamer - Responder
The back cover is sold here and can be found at the top of the page.
Cwoodyard -
Can i buy this bottom replacement piece here or is this instructions on how to do it?
itsRadioBiz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 37
Últimos 30 dias: 137
Duração total: 64,913
