Ir para o conteúdo principal
MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement
O que você precisa
  1. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Remove the lower case screws: passo 1, imagem 1 %32
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - Responder
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - Responder
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - Responder
    I use a magnetic mat and place the screws in order on that :)
    Cary B - Responder
  2. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Lift the lower case away: passo 2, imagem 1 %32
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - Responder
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - Responder
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Battery: passo 3, imagem 1 %32
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    Citação de gansodesoya:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - Responder
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - Responder
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - Responder
  4. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Fan: passo 4, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Fan: passo 4, imagem 2 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Fan: passo 4, imagem 3 %32
    • Use a spudger to pry up the fan connector out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
    The image is very misleading. This is why many people are breaking their connectors. Please correct this and make it VERY clear that one has to put the spudger straight behind the cables, NOT behind the connector, as shown in the pic.
    Giunia - Responder
    Thankfully there is a helpful guide in the comments on this post for fixing the socket in the likely event that you snap the sucker clean off like I did:
    I popped off the fan connection from the logic board...Fix?
    agoodcourage - Responder
    As Giunia said I too just broke the connector only because the photo shows to slide a spudger between the connector socket and the motherboard. I am now out of my only computer. This is VERY frustrating.
    Nha1234 - Responder
    Broke it as well the picture is very misleading.
    Christian Flores - Responder
    Local mobile repair shop soldered it back for me.. but it cost me twice as much as fan I ordered from china. They told me to use two tools in the future.. one to keep the edge down and other to gauge gently from under the cables...
    Bade -
  5. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 5, imagem 1 %32
    • Remove the following three screws:
    • One 7 mm T6 Torx screw
    • Two 5.4 mm T6 Torx screws
  6. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 6, imagem 1 %32
    • Lift the fan out of the upper case.
  7. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Logic Board: passo 7, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Logic Board: passo 7, imagem 2 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Logic Board: passo 7, imagem 3 %32
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Gently pull the display data cable connector away parallel to the board.
    • Do not pull the connector upwards, or you may damage the connector.
    On my system the pad on top of the connector was shifted making the bracket difficult to rotate into the up position. The bracket looks like a handle so my first instinct was to pull it straight up. Big mistake. I ended up popping the brass guard off the connector on the logic board. The instructions could benefit from an arrow indicating the direction to pull and rotation of the bracket.
    highnoontoday - Responder
  8. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 8, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 8, imagem 2 %32
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 8.6 mm Phillips
    • One 5.6 mm Phillips
    • Lift the display data cable bracket out of the upper case.
  9. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 9, imagem 1 %32
    • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
    Push it straight down. It should snap in.
    BobG - Responder
    The first time i tried this on a MBP 13 I broke the connector form the board. It should be noted that you have to be very careful in this step, as the plug fits very tightly and you can easily use too much force to tear the connector from the board. Use a second spudger to hold down the connector at its border and try very gently using a second spudger to move the plug out of the connector upwards.
    Joachim Kathmann - Responder
  10. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 10, imagem 1 %32
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and can be easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
    As mentioned, the socket can be easily damaged when re-inserting it. I didn't care enough and one pin was damaged. Wifi was not detected.
    Hopefully the pin was not broken (only bent). Putting it back in its correct position, the wifi re-appeared.
    Arnaud ROSAY - Responder
  11. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 11, imagem 2 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 11, imagem 3 %32
    • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
  12. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 12, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 12, imagem 2 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 12, imagem 3 %32
    • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
    • Use your spudger to slide the keyboard ribbon cable out of its socket.
    Sometimes spulger is not the best tool to slide the cable out. If it is difficult to slide, try two toothpicks to pull the cable from two sides simultaneosly.
    Leo Nikitin - Responder
    Toothpicks did the trick, thanks
    Gábor SEBESTYÉN -
    As Mateo said, replacing the zif cable is NOT easy, and in this case, will leave you with a computer that won't power on- this cable connects the power button. I learned a trick somewhere for dealing with these cables- put a piece of good sticky tape on the cable, and use it to pull it back into the connector. Works every time.
    stevesontheroad - Responder
    Yeah! The tape trick worked for me. Thanks!
    Ted Bishop -
    Thank you Steve, it’s works perfectly.
    never_forever18 -
  13. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 13, imagem 1 %32
    • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
    Be very careful while taking this black tape off. I accidentally broke the chip off the motherboard and so my keyboard is not backlit any more.
    Asim Akath - Responder
  14. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 14, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 14, imagem 2 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 14, imagem 3 %32
    • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
    • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
    Be especially careful as my hole socket detached from the board. It would have helped to vertically press the socket to the board with the tip of a spudger. Thus partially blocking the strap, you can first peel the free end, then change position and peel the rest. Slide the ribbon cable perfectly horizontally.
    Rainer - Responder
    I had the same issue of trying to get the ZIF cable back in but found that if I used a piece of scotch tape, it worked. I followed this guide. MacBook unibody keyboard ribbon cable won't go in
    spearson - Responder
    A reassembly trick that works for me is to use some 3/4" blue painters tape to stick to the very back (lower end) of the ribbon cable so I can pull it up and back before locking the cam. Trying to get a good grip without cutting, or crimping the ribbon means no tweezers or pliers can be used.
    originalmachead - Responder
  15. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 15, imagem 1 %32
    • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
    If you’re swapping top cases, you might need to remove the battery indicator from the case and swap it to the replacement top case. It attaches with three very tiny Phillips screws. I wasn’t aware that my replacement top case didn’t have this part and got confused when reversing the steps to reassemble and I didn’t have this connector. I had to take the battery back out in order to swap the indicator over.
    Mark Barnes - Responder
    Interesting this guide doesn’t have you disconnect the battery after step 2 then shows it unplugged already in step 14.
    plink53 - Responder
    I would recommend revision to this guide to put battery disconnection as the first step after opening the bottom case. First rule of logic/mother boards: don’t work on or around if power is applied.
    dsfeehan - Responder
  16. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 16, imagem 1 %32
    • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
    on the Australian/Asia version speaker cable is located underneath the logic board.
    linuxuser101 - Responder
    Norwegian/European versjon too. Recommend using a pincer to lift it up.
    Note you’re not supposed to only remove the rubber, in fact that should stay on
    eisa01 - Responder
  17. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 17, imagem 1 %32
    • Remove the following screws:
    • Two 7 mm T6 Torx screws from the DC-In board
    • Five 3.3 mm T6 Torx screws
    • Two 4 mm T6 Torx screws
  18. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 18, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 18, imagem 2 %32
    • Removing the battery before lifting out the logic board is not strictly required, but makes removing the logic board easier and safer. If you leave your battery in, be especially careful not to bend the logic board against the battery's case near its bar code.
    • Remove the following Tri-point screws securing the battery to the upper case:
    • One 5.5 mm Tri-point screw
    • One 13.5 mm Tri-point screw
    • Lift the battery out of the upper case.
  19. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 19, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 19, imagem 2 %32
    • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
    • Pull the logic board away from the side of the upper case and remove it, minding the DC-In board that may get caught.
    Be careful while taking the board out, as the heatsink usually is caught by the optic drive.
    mid 2012: Careful of the left speaker (on your right because unit is upside down). Gently remove with spudger tool before removing logic board and when reinstalling press firmly back into place with spudger. Install speaker after putting logic board in place but before installing screws.
    JASON CULP - Responder
    Step 18 is out of order. Steps following this show it still installed, which is confusing.
    plink53 - Responder
  20. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Upper Case: passo 20, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Upper Case: passo 20, imagem 2 %32
    • Remove two Phillips screws securing the hard drive bracket to the upper case.
    • The screws remain captive to the bracket.
    • Lift the the retaining bracket out from the upper case.
  21. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 21, imagem 1 %32
    • Lift the hard drive from its free edge and pull it out of the chassis, minding the cable attaching it to the computer.
  22. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 22, imagem 1 %32
    • Disconnect the hard drive by pulling the hard drive cable connector away from the drive.
  23. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 23, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 23, imagem 2 %32
    • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
    • Two 1.5 mm Phillips screws.
    • Two 4 mm Phillips screws.
    • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
    • Carefully peel the hard drive and IR sensor cable from the upper case.
    The orange-highlighted screws here are far longer than 4mm, aren't they?
    Shelley - Responder
  24. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 24, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 24, imagem 2 %32
    • Remove the following screws securing the subwoofer to the upper case:
    • One 3.8 mm Phillips screw.
    • One 5 mm Phillips screw
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  25. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 25, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 25, imagem 2 %32
    • Remove the two 10 mm Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
    • Lift the camera cable bracket out of the upper case.
  26. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 26, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 26, imagem 2 %32
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Lift the optical drive from its right edge and pull it out of the computer.
  27. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 27, imagem 1 %32
    • Peel back the small piece of black tape covering the right speaker cable.
    • Be careful, as the power button ribbon cable is directly under this piece of tape.
  28. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 28, imagem 1 %32
    • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
    I found it easiest to start at the bottom (hard drive side) of the speaker.
    Michael Vovaris - Responder
  29. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 29, imagem 1 %32
    • Lift the subwoofer and right speaker assembly out of the upper case.
  30. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 30, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 30, imagem 2 %32
    • Remove the two outer T8 Torx screws securing each side of the display bracket to the upper case (4 screws total).
  31. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 31, imagem 1 %32
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the T8 Torx screw from the lower display bracket.
  32. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 32, imagem 1 %32
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  33. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 33, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 33, imagem 2 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 33, imagem 3 %32
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
  34. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement, Upper Case: passo 34, imagem 1 %32
    • Remove the four 1.2 mm Phillips screws highlighted in red.
  35. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 35, imagem 1 %32
    • Carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
    • De-route the trackpad cable through its slot cut into the upper case.
    I concur with Anonymous 596. There is a support wall that runs front to back, under keyboard, held down by 2 Phillips screws that will need to be removed & transferred to new upper case. You can see it being touched by index finger in this pic.
    Macrepair SF - Responder
  36. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 36, imagem 1 %32
    • Pull the trackpad away from the outer edge of the upper case.
    • Remove the trackpad and set it aside.
    There's a missing step here. In addition to the trackpad, there's an aluminum structural piece that sits under the center of the keyboard, that has to be migrated from old to new case. It's clearly shown to the left of the repair-person's right hand in step 44.
    anonymous 596 - Responder
  37. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 37, imagem 1 %32
    • In the following steps, you will be working on your new upper case.
    • Use a T6 Torx screwdriver to loosely install the 1.1 mm set screw included with your new upper case into its tapped hole near the middle of the trackpad opening on your new upper case.
    • Only tighten it about one turn for now.
    I bought a used replacement case and had to move a few parts from the old case to the replacement. This included the battery indicator cable, the clips for the trackpad and the bracket in the center of the top case. So worth it at this point to compare your old and replacement case to be sure everything you need is there.
    Ron - Responder
    my new case came with the set screw already installed, and i couldn’t loosen it. i didn’t want to strip it and cause a bigger problem, so i left it alone. the trackpad seems to work fine so far regardless, although i may take the bottom case off and play with it a little if i get a chance.
    i also (just like Ron) had to move the trackpad clips, battery indicator and center bracket to the new case. they were not included.
    Matt - Responder
  38. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 38, imagem 1 %32 MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 38, imagem 2 %32
    • Carefully insert the cable from your old trackpad through its slot cut into your new upper case.
    • Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
    • Pull the trackpad cable as you seat the trackpad into its void in your new upper case.
  39. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 39, imagem 1 %32
    • Insert a 1.2 mm Phillips screw into each of the outer holes drilled into the trackpad (two screws total).
    • You'll install the rest in a bit.
    • Tighten the screws, then back them out about a quarter turn to aid in aligning your trackpad during the next few steps.
  40. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 40, imagem 1 %32
    • While continually trying to click your trackpad, gently tighten the T6 Torx set screw until the clicks return to their factory "feel."
    • You can tell when the screw is tightened just right by the noise it makes when the trackpad clicks. If the set screw is too loose, the trackpad will have excessive play before it clicks. If it is too tight, the trackpad will click too easily and won't make the characteristic loud mouse clicking noise.
  41. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 41, imagem 1 %32
    • Next, flip your upper case over so the keyboard side is facing up.
    • Align the trackpad so it is centered in its hole cut into the upper case.
    Pour l’alignement du Tradpad mettez sur les 4 cotés des morceaux de feuille A4😜.
    Caruso - Responder
  42. MacBook Pro 13" Unibody Mid 2010 Upper Case Replacement: passo 42, imagem 1 %32
    • Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
    • If its alignment looks good, install the rest of the Phillips screws along the inner edge of the trackpad.
    • Before reassembling your machine, verify that the set screw is still installed in a position so the mouse will click correctly.
    You can actually replace the keyboard alone fairly easily! I don't know why everyone says you have to replace the whole top case, because if you've got the guts to go this far, you might as well just peel back the illuminator cover and get to work pulling all those tiny screws in the keyboard... Just be careful when peeling up the black adhesive keyboard cover, because you will need to replace it. I used the edge of the ifixit Sesame tool (very thin flat metal opening tool) to carefully slip under any bits of adhesive, and had the keyboard exposed in no time. Also be careful because the clear plastic sheet is actually the keyboard illuminator. Once under all that, it's a mere 50 or so tiny screws, 2 screws in the power button backing, and you've got the keyboard out. Use a magnetized #000 phillips, it will make life much easier than anything else.
    Logan Bean - Responder
    Absolutely right. I just replaced a keyboard the same way without much problem but i just want to add that those tiny screws need extra care as the heads can get damaged very easily. If damaged, they become very difficult to remove.
    Masood -
    I did just that on my mid-2010 MacBook Pro about a month ago and sadly will have to do it to my wife's Early-2011 one next week. I was cleaning all the crap off her keyboard and apparently nuked the K and 0 keys on her keyboard. Probably my ply challenge was aligning the keyboard illuminator. It's still not aligned properly on mine so some keys are better lit than others, but otherwise it was a relatively easy fix and far cheaper than replacing the entire upper case.
    John Adam Wickliffe -
    I replaced my keyboard less than an hour ago. The biggest pain/most time consuming was reattaching the ZIF connector for the keyboard and backlight. No matter what I did I could not get the %#*@ thing to reattach. What sadist designs these things? I had to walk away from the project for an hour and finally success.
    All those screws will make you go crosseyed!
    Gordon - Responder
    It helps to put some tape along the cable going lengthwise to the cable, and then fold the end of the tape onto itself to give yourself something to hold onto. This will give you some leverage to get that puppy into the socket.
    maccentric -
    I’m glad you managed !!!
    I’m suffering :( take a part about 5 times…… ordered new (used) keyboard, the same results. I tested logic board in my daughter MAC, board works 100% no trouble ……. what could be wrong? there a secret how to reassemble keyboard parts together? I ripped a little bit black plastic thing, not top one with tiny connectors……
    In the end I have two keyboards, cleaned and taken a part, both of them acting identical when installed. Some keys respond by giving absolutely not relevant symbols, beeping noise come with almost every key i pressed…..
    Recovering after massive cappuccino spell after surprising hug :(((((
    Aleksandra Perry -
    I swear to post photo step by step, if I will achieve this one……….. assemble back to 100% working condition after total reassembling, ultrasonic cleaning and drying………. just keyboard panel.
    Give me nightmares :) will be first time I have so much trouble to fix………
    Aleksandra Perry -
    I'm wondering about putting it back together. Different wires and small parts etc were glued or adhered in some way to the case or sides or whatever, as it is put together in the beginning. Is that just to make it easier to put it back together? Should I try to stick them back the way they were with something? Can you use tape or glue if it's just a wire? I wouldn't want to use something that would melt...or is this not something to worry apout?
    ingwis - Responder
    I just used 1/4 polymide tape, and iFixit double sided tape. Works like a champ.
    Brent Hillyer -
Conclusão
65 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 38
Duração total: 76,742
