Introdução
Update your MacBook Pro with a new set of feet.
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Remove any broken or damaged feet.
Remove any pieces from the old foot that may have broken off in the foot hole.
Use tweezers to peel up and remove the old adhesive tape from the foot pad.
Align the new foot inside the foot pad.
Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
Lay the foot down while keeping it properly aligned.
Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
19 outras pessoas concluíram este guia.
2 comentários
Just wondering if melting the original pads from inside the case with a flame would help to fix them in place for a little longer.
I’d be a little wary of doing something like that. I don’t think it would help the pads stay in place very much, but it might make it really hard to clean the case when you do want to replace the pads. If you want to make the original pads last a little longer you can try pulling them off, cleaning off the old adhesive, and applying some new tape or glue.
