Ir para o conteúdo principal
MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement
O que você precisa
  1. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Remove the lower case screws: passo 1, imagem 1 %32
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Lift the lower case away: passo 2, imagem 1 %32
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Battery: passo 3, imagem 1 %32
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Fan: passo 4, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Fan: passo 4, imagem 2 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Fan: passo 4, imagem 3 %32
    • Use a spudger to pry the fan connector out of its seat, and straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  5. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 5, imagem 1 %32
    • Remove the following three screws securing the fan to the upper case:
    • One 6.5 mm Phillips.
    • One 5.5 mm Phillips.
    • One 4.5 mm Phillips.
  6. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 6, imagem 1 %32
    • Lift the fan out of the upper case.
  7. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Logic Board: passo 7, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Logic Board: passo 7, imagem 2 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Logic Board: passo 7, imagem 3 %32
    • Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
  8. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 8, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 8, imagem 2 %32
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips.
    • One 5 mm Phillips.
    • Lift the display data cable bracket out of the upper case.
  9. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 9, imagem 1 %32
    • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
  10. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 10, imagem 1 %32
    • In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  11. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 11, imagem 2 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 11, imagem 3 %32
    • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
  12. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 12, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 12, imagem 2 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 12, imagem 3 %32
    • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
    • Use your spudger to slide the keyboard ribbon cable out of its socket.
  13. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 13, imagem 1 %32
    • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
  14. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 14, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 14, imagem 2 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 14, imagem 3 %32
    • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
    • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
  15. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 15, imagem 1 %32
    • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
  16. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 16, imagem 1 %32
    • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
  17. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 17, imagem 1 %32
    • Remove the following screws:
    • Five 3.1 mm Phillips.
    • Two 3.9 mm Phillips.
    • Two 7 mm Phillips from the DC-in board.
  18. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 18, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 18, imagem 2 %32
    • Remove the following Tri-point screws securing the battery to the upper case:
    • One 5.5 mm Tri-point screw.
    • One 13.5 mm Tri-point screw.
    • Lift the battery out of the upper case.
  19. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 19, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 19, imagem 2 %32
    • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
    • Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
    • Be careful not to rip out the fragile connector plug of the microphone assembly.
  20. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Microphone: passo 20, imagem 1 %32
    • Peel the tape off covering the microphone cable connector.
  21. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 21, imagem 1 %32 MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 21, imagem 2 %32
    • Use the flat end of a spudger to pry the microphone cable connector up off the logic board.
    • Deroute the microphone cable from the channel in the left speaker.
  22. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement, Left Speaker: passo 22, imagem 1 %32
    • Remove the strip of tape covering the left speaker cable connector.
  23. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 23, imagem 1 %32
    • Use the flat end of a spudger to pry the left speaker connector up off the logic board.
  24. MacBook Pro 13" Unibody Mid 2009 Left Speaker Replacement: passo 24, imagem 1 %32
    • Carefully peel the left speaker assembly off the adhesive securing it to the logic board.
Conclusão
9 outras pessoas executaram este guia.
2 comentários
Hallo Walter, kannst Du mir bitte verraten welche A Nummer hat hier aufgeführten MAC?
Olga S - Responder
Hallo Olga, dieses MacBook hat die Nummer A 1278.
Fabian Neidhardt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 41
Duração total: 25,568
