Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide will show you how to replace your hard drive cable or tighten it if it is loose
  1. Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. Remove two Phillips screws securing the hard drive bracket to the upper case.
    • Remove two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
  5. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Confira os kits
    Enough RAM
    For All The Tabs
    Confira os kits
  6. Lift the the retaining bracket out of the upper case.
    • Lift the the retaining bracket out of the upper case.
  7. Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  8. Remove the hard drive cable by pulling its connector straight away from the hard drive.
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
  9. Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
    • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
    • Two 1.5 mm Phillips screws.
    • Two 9.5 mm Phillips screws.
  10. Slide the hard drive and IR sensor bracket away from the edge of the upper case. Carefully peel the hard drive and IR sensor cable from the upper case.
    • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
    • Carefully peel the hard drive and IR sensor cable from the upper case.
  11. Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  12. Lift the hard drive/IR sensor cable assembly out of the upper case.
    • Lift the hard drive/IR sensor cable assembly out of the upper case.
    • If your replacement part does not come with the hard drive bracket and indicator light, you will need to pull those off of the part you are removing and install them on the new part.
    • Your replacement part may come with several adhesive foam bumpers. These are to ensure a snug fit of both bracket and hard drive. Apply only as needed.
Conclusão
285 outras pessoas concluíram este guia.
Used a Phillips #00 and a creditcard. It's an easy job, takes about 10 minutes. :)
sjoerdstra - Responder
In step #8 the two small screws were very tight in my computer. The Phillips #00 was too large and damaging the screws. I changed to a Phillips #000 applied substantial pressure and voila, the screws came off.
Reassembly: placing the IR sensor cable (the one you"peeled off" in step #9) is a bit tricky. Start from the side opposite the IR sensor (the side with the two small screws of step 8) and press first along the short vertical side and then across towards the IR section. There should be a little left for a vertical section at the IR sensor end.
bgrinstein - Responder
Very Easy and clearly written instructions
omar - Responder
Can you illustrate how to attach the gold strip cable?
Rene - Responder
if i change the HDD cable and get the same results what could be the the real problem , because the original problem as we all know was the we were getting the question mark on the white screen .
Curtis O'brien - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 235
Duração total: 160,808
