Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Remova os 10 parafusos a seguir que fixam a estrutura inferior ao MacBook Pro 13" Monobloco:
Sete parafusos Phillips de 3 mm.
Três parafusos Phillips de 13,5 mm.
Levante ligeiramente a estrutura inferior e empurre-a em direção à parte traseira do computador para liberar as linguetas de montagem.
Este passo não foi traduzido. Ajude a traduzi-lo
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the subwoofer/right speaker cable connector up off its socket on the logic board.
Disconnect the camera cable by sliding it horizontally out of its socket.
If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
De-route the camera data cable from the channel in the optical drive.
Remove the following screws securing the camera data cable and right speaker to the upper case:
Two 8 mm Phillips screws.
One 4mm Phillips screw.
Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
Pull the display data cable connector straight away from its socket.
Remove the following two screws securing the display data cable bracket to the upper case:
One 7 mm Phillips screw.
One 5 mm Phillips screw.
Lift the display data cable bracket out of the upper case.
Use your Torx driver to remove the two outer 6.5 mm screws securing each of the two display brackets to the upper case (4 screws total).
Open your MacBook so the display is perpendicular to the upper case.
Place your opened MacBook on a table as pictured.
While holding the display and upper case together with your left hand, use your Torx driver to remove the remaining 6.5 mm screw from the lower display bracket.
Remove the last remaining 6 mm Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
Grab the clutch cover as shown and slide it toward the right side of the display.
Gently rock the clutch cover back and forth on its long axis while pulling it away from the display.
Do this action along the length of the clutch cover until you can lift it off the framework attaching it to the display.
Use the tip of a spudger to pry both AirPort antenna connectors out of their sockets on the AirPort board.
Remove the single 3 mm Phillips screw securing the AirPort card to the display nearest the AirPort antenna.
Remove the single 3.3 mm Phillips screw securing the camera cable retainer to the display.
Orient your display as shown and pull the black plastic camera cable retainer toward the right side of the display.
Remove the camera cable retainer.
Carefully pull the camera cable connector toward the right side of the display and out of its socket on the AirPort card.
Remove the remaining 3 mm Phillips screw securing the side of the AirPort card closest to the right clutch hinge.
Pull the AirPort card away from its heat sink and remove it from the display.
64 outras pessoas executaram este guia.
5 comentários
I am sick of the occaisonal misinformation iFixit provides. The longer cable that connects on the right side of the screen is so very obviously not just the camera cable. It is also the cable for the Airport and Bluetooth cards... This misinformation led me to spend 100€ on two LCD cables which I now have no use for.
I don't wish to just complain though of course. Can someone please correct this? On the other pages for this MBP the cable is listed in the same way.
The official Apple name for this cable is "camera cable", so that is what we call it. You'll have to take it up with Apple to change the name, as we try to stay consistent with how they name parts.
I think iFixit does an amazing job of being accurate, given that the guides are written based on physical tear-downs. As a small-time mac technician, I am eternally grateful for the unlimited use of free, comprehensive guides. Instead of complaining about free advice, you can easily submit an edit to the guide if it is truly in error. The bottom line with Apple products - they are impeccably engineered, although have some annoyingly tedious steps because of the compact nature. They are build to last, but BE GENTLE!!
The connector from the cable into the airport card is socketed in different ways on the pictures in step 21, i have noticed that the connector fits in either way, but what way is the right one? im asking because after i followed this guide my airportcard doesnt work anymore:(
see comment on step 22
