Introdução
Use this guide to replace a worn-out battery. If your battery is swollen, take appropriate precautions.
Vídeo de Apresentação
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the following two screws:
One 5.6 mm Tri-point screw
One 13 mm Tri-point screw
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
288 outras pessoas concluíram este guia.
15 comentários
as the label said, "Warning, do not remove the battery", is that any risks if I disobey it?
Actually Monika, the guide says that a Tri-wing is needed for two of the screws, which it is. My new battery came with a tool for that but I'd already discovered that it's easy to remove these two screws with a fine straight (non-Philip's head) driver.
Thanks Phillip Takahashi (and your five co-authors). That was a straight forward and clear guide.
Hello
I changed the battery and it keeps telling me that there is replacement needed
Also the indicator said the battery is 150% charged.
Is that normal and how do i remove the status that said the battery isn't ok and change it in to an ok status?
Please help
