This step is untranslated. Help translate it
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use your fingers to pry the lower case away from the body of the MacBook near the vent.
Remove the lower case.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Pull the two RAM retaining arms away from the center of the RAM chip.
339 other people completed this guide.
11 Comments
What kind of ram should I buy? DDR2 or DDR3?
It takes only DDR-3 RAM.
Is a 8gb early 2011 macbook pro maxed out, or can I upgrade to 16?
I'm asking because I read in http://www.crucial.com/store/mpartspecs.... that it can actually take 16gb. Thanks!
Yup! I upgraded to a 16 GB DDR3 Corsair mac memory kit from Newegg and it works like a charm. I got this kit: https://www.newegg.com/Product/Product.a...
screenshots below:
