Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
  2. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 2, imagem 1 %32
    • Carefully pull the camera cable out of its socket on the logic board.
    • Though not recommended by iFixit staff, some users opt to omit this step completely. For information on this, see the step comments.
    • Pull the cable parallel to the face of the logic board. Pulling it upward may damage the logic board or the cable itself.
  3. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 3, imagem 2 %32
    • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
    • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  4. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 4, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 4, imagem 2 %32
    • Use the tip of a spudger to pry the antenna connector closest to the logic board up from its socket on the AirPort/Bluetooth board.
    • De-route the antenna cable from under the finger molded into the AirPort/Bluetooth bracket.
  5. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 5, imagem 1 %32
    • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
  6. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 6, imagem 2 %32
    • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
    • Move the AirPort/Bluetooth assembly and the subwoofer away from the top of the optical drive.
  7. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 7, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 7, imagem 2 %32
    • Pull the right speaker/subwoofer cable out from under the retaining finger near the side of the optical drive.
    • Pull the right speaker/subwoofer cable upward to disconnect it from the logic board.
  8. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 8, imagem 1 %32
    • Use the flat end of a spudger to pry the hard drive cable connector up from its socket on the logic board.
    • Bend the hard drive cable away from the optical drive.
  9. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 9, imagem 1 %32
    • Use the flat end of a spudger to pry the optical drive connector up from its socket on the logic board.
  10. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 10, imagem 1 %32
    • Remove the three 2.7 mm Phillips screws securing the optical drive to the upper case.
  11. MacBook Pro 13" Unibody Early 2011 Optical Drive Replacement: passo 11, imagem 1 %32
    • Pull the optical drive upward from its edge closest to the display and remove it from the upper case.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 717
