Ir para o conteúdo principal
MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain attached to the hard drive bracket.
  2. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
  3. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: passo 3, imagem 1 %32
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Don't try to completely remove the hard drive just yet. It is still attached to the hard drive cable.
  4. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: passo 4, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: passo 4, imagem 2 %32
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Ao todo: 1,352
