Ir para o conteúdo principal
MacBook Pro 13" Unibody Early 2011 Feet Replacement
O que você precisa
  1. MacBook Pro 13" Unibody Early 2011 Feet Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 2, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 2, imagem 2 %32
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Early 2011 Feet Replacement, Feet: passo 3, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Feet Replacement, Feet: passo 3, imagem 2 %32 MacBook Pro 13" Unibody Early 2011 Feet Replacement, Feet: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 4, imagem 1 %32
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 5, imagem 1 %32
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 6, imagem 1 %32
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 7, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 7, imagem 2 %32 MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 7, imagem 3 %32
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 13" Unibody Early 2011 Feet Replacement: passo 8, imagem 1 %32
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
Conclusão
31 outras pessoas executaram este guia.
Adam O'Camb
Membro desde: 04/11/15
198.503 Reputação
Autoria de 416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 48
Duração total: 10,326
