Ir para o conteúdo principal
MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement
O que você precisa
  1. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disable Auto Boot: passo 1, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disable Auto Boot: passo 1, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disable Auto Boot: passo 1, imagem 3 %32
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - Responder
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - Responder
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - Responder
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - Responder
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - Responder
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - Responder
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - Responder
    Not able to do that with damaged screen
    richardjgreen - Responder
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - Responder
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - Responder
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - Responder
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - Responder
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - Responder
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - Responder
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - Responder
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - Responder
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - Responder
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - Responder
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - Responder
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - Responder
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - Responder
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - Responder
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - Responder
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - Responder
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - Responder
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
  2. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Remove the lower case: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Before you proceed, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 3, imagem 2 %32
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight separation between the lower case and the chassis.
  4. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 4, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 4, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 4, imagem 3 %32
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 5, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 5, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 5, imagem 3 %32
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 6, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 6, imagem 3 %32
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 7, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 7, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 7, imagem 3 %32
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • It may help to pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    Tip: If you use a spudger as a lever, placing the thin end inside the hinge and pressing lightly towards the bottom casing, it pops out quite easily.
    Carlos Gomez - Responder
  8. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 8, imagem 1 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
    Hab zum Schluss das Blaue OpeningTool benutzt und am Rahmen in der nut eingehackt um den Deckel final hinein zu drücken. Da er per Hand nur bis zu einem gewissen Punkt geht
    Maximilian Koos - Responder
  9. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disconnect the battery: passo 9, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Disconnect the battery: passo 9, imagem 2 %32
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 10, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 10, imagem 2 %32
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 11, imagem 2 %32
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
    • Locking tabs on ZIF connectors are fragile, so be gentle when using the tip of the spudger.
  12. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 12, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 12, imagem 2 %32
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  13. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 13, imagem 1 %32
    • Fold the battery board data cable back and out of the way.
    • If you're replacing your battery, you may need to completely remove and transfer this cable to your new battery. Disconnect both ends and carefully remove the cable. During installation, be careful not to install it upside-down or backwards—note the orientation in the photos.
  14. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 14, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 14, imagem 2 %32
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
    io ho trovato un Torx T4 invece del T5.
    Stefano Supino - Responder
    Ciao Stefano! Grazie per il commento. Infatti c’è sempre una certa tolleranza fra il cacciavite e la testa delle viti. Quindi è possibile che un cacciavite più grande o più piccolo sia più “comodo” in certi casi. Buona riparazione!
    Claire Miesch -
    konnte diese Verbindung nicht lösen. Zu sehr angezogen
    Lang Werner - Responder
  15. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 15, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 15, imagem 2 %32
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket.
    • If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
    Hello, I have damaged this connector and it is now loose with the logic board. It is possible to replace this connector?
    Thanks
    deejaygav - Responder
    Please save yourself a pile of money and read this before doing this step: I bricked my MacBook by not being extremely careful and making sure to NOT touch the connector together as I took it apart. Ouch ouch ouch. 😫
    Hudson Gomez - Responder
  16. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Remove the antenna cable assembly: passo 16, imagem 1 %32
    • Remove the four 3.3 mm T3 Torx screws securing the plastic covers on top of the display hinges.
  17. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 17, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 17, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 17, imagem 3 %32
    • Remove both plastic hinge covers.
  18. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 18, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 18, imagem 2 %32
    • Remove the two 3.1 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  19. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 19, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 19, imagem 2 %32
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
    I have done 2 these these exact same 2019 MacBooks now, and both times The screw on the right seems to not be a T3. At first it appeared that I stripped it, but once I got to the second one and I was very gentle with it, it’s a totally different screw. And I can’t figure out what it is… But the T3 or the T4 will not remove it. Neither will a Pentolope. I just removed the left screw, and then I pivoted the cover away so I could remove the connecter. Anyone else having this issue?
    noahmadsen - Responder
    You’re right, noahmadsen, they’re super slightly, but different.
    Leon Mertvoy - Responder
  20. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 20, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 20, imagem 2 %32
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  21. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 21, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 21, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 21, imagem 3 %32
    • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
    • Use a pair of tweezers to remove the two aluminum covers.
    FYI.....during reassembly, the new screen may come with these already attached so compare the old screen to the new one before installing.
    Lonnie Smith - Responder
  22. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 22, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 22, imagem 2 %32
    • Remove the four 3.3 mm T5 Torx screws on both sides, which secure the antenna cable assembly.
    • Also remove the twelve 1.1 mm P2 pentalobe screws on both sides.
    • These small screws can strip easily, so make sure your P2 pentalobe driver is in good condition before applying pressure.
  23. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 23, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 23, imagem 2 %32
    • Carefully disconnect the two antenna coax cables by prying them straight up from the logic board.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  24. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 24, imagem 1 %32
    • Remove the 3.4 mm T5 Torx screw securing the two antenna coax cables to the main board.
  25. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 25, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 25, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 25, imagem 3 %32
    • Use an opening pick to lever out the antenna cable assembly in the areas shown.
    • Don't slide the opening pick from side to side, because there are two display cables that can be damaged.
    I stripped these, is there any tips on getting these out?
    Mark Higgins - Responder
    Mark, here's a guide with tips for removing stripped screws. Hope it helps—best of luck!
    Carsten Frauenheim -
  26. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 26, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 26, imagem 2 %32
    • Carefully remove the antenna assembly while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
  27. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 27, imagem 1 %32
    • Remove the antenna cable assembly.
    • During reassembly, gently pinch the cable bundle together and guide it under the frame into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
    After doing the job the first time, when I opened the display there was something clicking loudly. I had found out that this antenna assembly wasn’t put back properly. When reinstalling this, there is a flat metal piece on the bottom centre of the antenna assembly. Mine became bent for some reason. I had to bend it back straight. It needs to click back in to top case. Problem solved!
    Same happened to me, there’s a small canal in the top case where the antena must be vertically inserted, if you just push it horizontally in place it will fit and you will be able to reassemble the computer, but the antenna will be sligthly bent and cause friction with the screen when opening.
    Carlos Morales -
  28. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement, Remove the display assembly: passo 28, imagem 1 %32
    • Remove the four 3.9 mm T3 Torx screws securing the spring hinges of the two display cables.
    Stripped one on each side. Any suggestions?
    [deleted] - Responder
  29. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 29, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 29, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 29, imagem 3 %32
    • Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the spring hinge.
    • Use a pair of tweezers to pull the spring hinge of the display cable out of its bracket.
    • Repeat this step with the right spring hinge of the display cable assembly.
  30. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 30, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 30, imagem 2 %32
    • Fully open the screen and stand your MacBook Pro up on one side.
    • While steadying the MacBook pro with your free hand, remove the three T8 Torx screws from the lower display hinge.
    • Remove the remaining three T8 Torx screws from the upper display bracket.
  31. MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 31, imagem 1 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 31, imagem 2 %32 MacBook Pro 13" Two Thunderbolt Ports 2019 Display Assembly Replacement: passo 31, imagem 3 %32
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
    • Remove the display/screen assembly, being careful not to snag it on any cables.
    When reassembling, make sure to align the back edge of the new display assembly (hinge side) with the edge of the MacBook body, then tighten the hinge screws. Misalignment can cause the MacBook to open and close improperly. It should feel smooth where the gaps are between the two halves.
    Marc Jacobson - Responder
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
14 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
113.086 Reputação
Autoria de 338 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
5 comentários
Un tout grand merci!
vpirart - Responder
Are these the same steps for the 2020?
Axel - Responder
After replacing the display, the display works fine but the touch bar can’t work. Anyone comes across the same problem or have any idea what’s going on?
VincentZ - Responder
Why does the guide suggest purchasing the "MacBook Pro 13" Retina (A1708, A2159) Display Cable "
Richard Ness - Responder
Replaced my display with a genuine used panel and the true tone still worked. However, be very careful of the touchbar flex.
Tain Peacock - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 28
Últimos 7 dias: 119
Últimos 30 dias: 582
Duração total: 27,097
