Ir para o conteúdo principal
  1. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 1, image 1 of 3 : step 1, image 2 of 3 : step 1, image 3 of 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. Este passo não foi traduzido. Ajude a traduzi-lo
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 3, image 1 of 2 : step 3, image 2 of 2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 4, image 1 of 3 : step 4, image 2 of 3 : step 4, image 3 of 3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 5, image 1 of 3 : step 5, image 2 of 3 : step 5, image 3 of 3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 6, image 1 of 3 : step 6, image 2 of 3 : step 6, image 3 of 3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 7, image 1 of 3 : step 7, image 2 of 3 : step 7, image 3 of 3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 8, image 1 of 3 : step 8, image 2 of 3 : step 8, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 9, image 1 of 2 : step 9, image 2 of 2
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 10, image 1 of 2 : step 10, image 2 of 2
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 11, image 1 of 2 : step 11, image 2 of 2
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
  12. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 12, image 1 of 2 : step 12, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  13. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 13, image 1 of 2 : step 13, image 2 of 2
    • Fold the battery board data cable to the side and out of the way.
  14. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 14, image 1 of 2 : step 14, image 2 of 2
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 15, image 1 of 2 : step 15, image 2 of 2
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  16. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 16, image 1 of 3 : step 16, image 2 of 3 : step 16, image 3 of 3
    • Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
    • Remove both plastic hinge covers.
  17. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 17, image 1 of 2 : step 17, image 2 of 2
    • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  18. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 18, image 1 of 2 : step 18, image 2 of 2
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
  19. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 19, image 1 of 2 : step 19, image 2 of 2
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  20. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 20, image 1 of 3 : step 20, image 2 of 3 : step 20, image 3 of 3
    • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
    • Use a pair of tweezers to remove the two aluminium covers.
  21. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 21, image 1 of 2 : step 21, image 2 of 2
    • Remove the four 3.9 mm T5 Torx screws (two from each side) securing the antenna cable assembly.
    • Also remove the twelve 1.1 mm P2 pentalobe screws (six from each side).
  22. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 22, image 1 of 3 : step 22, image 2 of 3 : step 22, image 3 of 3
    • Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  23. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 23, image 1 of 1
    • Remove the 2.8 mm T5 Torx screw securing the three antenna coax cables to the main board.
  24. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 24, image 1 of 3 : step 24, image 2 of 3 : step 24, image 3 of 3
    • Use an opening pick to lever out the antenna cable assembly in the areas shown.
    • Don't slide the opening pick from side to side, because there are two display cables that can be damaged.
  25. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 25, image 1 of 2 : step 25, image 2 of 2
    • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
  26. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 26, image 1 of 1
    • Remove the antenna cable assembly.
    • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
  27. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 27, image 1 of 1
    • Remove the four 3.9 mm T3 Torx screws securing the two display cable cover springs.
  28. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 28, image 1 of 3 : step 28, image 2 of 3 : step 28, image 3 of 3
    • Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
    • Use a pair of tweezers to pull the cover spring of the display cable out of its recess.
    • Repeat this step with the right cover spring of the display cable assembly.
  29. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 29, image 1 of 2 : step 29, image 2 of 2
    • Fully open the screen and stand your MacBook Pro up on one side.
    • While steadying the MacBook pro with your free hand, remove the three T8 Torx screws from the lower display hinge.
    • Remove the remaining three T8 Torx screws from the upper display bracket.
  30. Este passo não foi traduzido. Ajude a traduzi-lo
    : step 30, image 1 of 3 : step 30, image 2 of 3 : step 30, image 3 of 3
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
    • Remove the display/screen assembly, being careful not to snag it on any cables.
Linha de Chegada
66 outras pessoas concluíram este guia.
27 comentários
What is the ribbon cable that you must remove before disconnecting the battery do?
Max4r - Responder
your mom.
all joking aside, its the communication between the logic board and the battery controller (cycle count, battery health etc)
Joe Jankins -
What is the exact P2 bit you need to remove the 12 screws holding the antenna bar? I ordered a P2 bit on Amazon that says it’s 0.8mm P2 bit and it’s too big. Not sure if they shipped me the wrong one or what. Been trying to find out exactly what bit to use and no luck so far.
Tyson Roehrkasse - Responder
Pentalobe P1L from Wiha tools fits perfectly.
Robin Ray -
What about the display ribbon cable ?
I have a bad cable and don’t want to spend 400 on display assy when the cable is available on this site for 25
Robin Bonathan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 83
Últimos 7 dias: 822
Últimos 30 dias: 3,351
Duração total: 125,965
