Peças
Não são necessárias peças.
  1. follow steps to remove bottom case if needed. how to remove bottom case. with bottom case removed, begin with disconnecting the battery. this is done by fist moving the ribbon cable out of the way of the screw that secures the battery contact. Once unscrewed, lift flap to interrupt contact to battery. with bottom case removed, begin with disconnecting the battery. this is done by fist moving the ribbon cable out of the way of the screw that secures the battery contact. Once unscrewed, lift flap to interrupt contact to battery.
    • follow steps to remove bottom case if needed. how to remove bottom case.
    • with bottom case removed, begin with disconnecting the battery. this is done by fist moving the ribbon cable out of the way of the screw that secures the battery contact. Once unscrewed, lift flap to interrupt contact to battery.
  2. next, remove the antenna bar. unlike the previous generation MacBook pros, the wifi antenna is not attached to the display assembly. To remove the antenna bar, start by removing the 12 screws located above the left/right heat sink vents by using a Pentalobe-2 (P2) bit. next, remove the shield plates by taking out the 8 screws circled in green.
    • next, remove the antenna bar. unlike the previous generation MacBook pros, the wifi antenna is not attached to the display assembly.
    • To remove the antenna bar, start by removing the 12 screws located above the left/right heat sink vents by using a Pentalobe-2 (P2) bit.
    • next, remove the shield plates by taking out the 8 screws circled in green.
    • after the shields are removed, lift up on the center snap-in connector on the antenna bar.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. remove the screws securing the antenna bar in place. disconnect the antenna cables and remove the bracket screw located beneath the cables. disconnect the antenna cables and remove the bracket screw located beneath the cables.
    • remove the screws securing the antenna bar in place.
    • disconnect the antenna cables and remove the bracket screw located beneath the cables.
  5. remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing. remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing. remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing.
    • remove antenna bar by lifting and sliding it out of the unit. The antenna cables will slide out from underneath the heatsink and through an opening located where the red arrow is pointing.
  6. with the antenna bar removed, it is now time to remove display assembly. it is recommended to have the display at 90degree angle for removal. remove the screws indicated by the red circles. (*there will be a plastic black covering over the display hinges. it will need to be removed first to expose the hinges.) with the antenna bar removed, it is now time to remove display assembly. it is recommended to have the display at 90degree angle for removal. remove the screws indicated by the red circles. (*there will be a plastic black covering over the display hinges. it will need to be removed first to expose the hinges.)
    • with the antenna bar removed, it is now time to remove display assembly. it is recommended to have the display at 90degree angle for removal. remove the screws indicated by the red circles. (*there will be a plastic black covering over the display hinges. it will need to be removed first to expose the hinges.)
Conclusão
9 outras pessoas concluíram este guia.
Nicholas H. of Experimac
435 reputação
Autoria de 1 guia
What is the ribbon cable that you must remove before disconnecting the battery do?
Max4r - Responder
Hello
In Step 5 you indicate to remove the screws in the red circles, what about the ribbon cables below the central red-circled screws? Those ribbon cables seem to connect the screen to the motherboard.
Best regards
Alex
info - Responder
It's like this company started as a passionate team who wanted to be the first to present fool-proof instructions how to repair your own device and now everyone's like slacking off and got bored. Why not describe the first thing we're removing? Why are you no longer giving the screw dimensions? Why are you skipping steps? Where is the LCD cable? Where is pretty white background? Why is this guide not on the A1706 main page?
skia.021 - Responder
I agree.
What about required tools? Seems like even the basics are missing or lacking.
Jimmy M -
I’m looking for the same info. To be fair to iFixit, this is a community member’s post from what I can tell, not iFixit’s own.
antidumb -
Visualizar Estatísticas:
Últimas 24 horas: 47
Últimos 7 dias: 278
Últimos 30 dias: 1,454
Todo: 13,391
