Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Use this guide to replace the fan.
Don't forget to follow our thermal paste application guide before you reinstall your heat sink.
    • Two 2.3 mm Pentalobe screws
    • Eight 3.0 mm Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. The lower case is connected to the upper case with two plastic clips near its center. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. If necessary, remove the plastic cover adhered to the battery contact board.
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board. Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  6. Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. Carefully remove the rubber fan bumper from the edge of the heat sink. The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct. The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
    • Carefully remove the rubber fan bumper from the edge of the heat sink.
    • The fan bumper wraps around the heat sink and fits into slots in the fan duct. During reassembly, be sure to fit the tabs into the notches in the fan duct.
  8. Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws. Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
    • Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
  9. Remove the following screws securing the heat sink to the logic board:
    • Remove the following screws securing the heat sink to the logic board:
    • Four 2.6 mm T5 screws
    • One 2.4 mm Phillips #000 screw
  10. Remove the heat sink from the laptop. When reassembling your computer, follow our thermal paste application guide to reapply the thermal paste.
  11. Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board. Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
    • Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
  12. Peel the iSight camera cable off the fan housing to fold it out of the way. Peel the iSight camera cable off the fan housing to fold it out of the way.
    • Peel the iSight camera cable off the fan housing to fold it out of the way.
  13. Use the tip of a spudger to flip the tab on the fan's ZIF connector. Carefully pull the fan cable straight out of its socket. Carefully pull the fan cable straight out of its socket.
    • Use the tip of a spudger to flip the tab on the fan's ZIF connector.
    • Carefully pull the fan cable straight out of its socket.
  14. Remove the following screws securing the fan to the upper case:
    • Remove the following screws securing the fan to the upper case:
    • One 5.0 mm T5 Torx screw
    • Two 3.6 mm T5 Torx screws
  15. Lift the end of the fan closest to the display hinge and remove the fan from the upper case. Lift the end of the fan closest to the display hinge and remove the fan from the upper case. Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
    • Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
Conclusão
18 outras pessoas concluíram este guia.
Sam Goldheart
Membro desde: 18/10/2012
410.607 Reputação
547 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
119 Membros
11.532 Guias de autoria
Very clear guide, and highly informative photos. It might be useful to add that the PL5 screws on the back of the case do not insert vertically. These insert at a slight angle and attempting to insert them straight will cause cross treading.
Robert Chave - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 94
Últimos 30 dias: 531
Duração total: 33,892
