Introdução
Use this guide to replace the trackpad. This procedure involves using adhesive remover to remove the battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
O que você precisa
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Remove the five 3.7 mm T5 Torx screws securing the battery to the upper case.
Alternatively, if you are using the hot iOpener method, skip the following three steps.
Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
Do not wear contact lenses without eye protection.
Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
Repeat this procedure with the adjacent battery cell:
Apply a small amount of liquid adhesive remover under the battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
Alternatively, re-heat this section with your iOpener if needed.
Push a plastic card about an inch between the battery cell and the upper case, and slowly pry the cell up to separate all of the adhesive.
Repeat the above procedure to separate the two leftmost battery cells from the upper case.
Remember to apply a small amount of adhesive remover to each battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
Use a second plastic card to separate the two leftmost battery cells from the upper case.
To separate the adhesive securing the final two, middle battery cells, apply a few more drops of liquid adhesive remover (or your iOpener) to each cell.
It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
Insert the card about an inch between the left-center battery cell and the upper case, separating the adhesive between the cell and the case.
Remove the battery.
With a little luck, you can slowly pull out each strip of adhesive with your fingers.
Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
Place a reheated iOpener over the trackpad cover plate to soften the adhesive securing it to the upper case.
41 outras pessoas concluíram este guia.
9 comentários
It's also worth mentioning that if your new trackpad doesn't click - there is a T6 torx adjustment screw located dead center of the bottom frame, below the battery (but not underneath it, so battery removal isn't required).
Turning this screw counterclockwise or clockwise will increase or decrease the travel of the trackpad clicking action. When i installed my replacement pad, it was not clicking at all - but turning this screw a bit counterclockwise fixed that problem!
This is fantastic. Thanks, I was able to replace the trackpad for about $50; the authorized Apple shop in my area wanted $500.
